How do I upgrade the memory on the 12GB model?
A friend of mine has a 12GB model of this device and I understand that this does not contain a hard drive. How do I add an internal hard drive so that I can increase the memory?
Hi Alex. You or your friend must buy HDD bracket. This operation is easy and will not cancel warranty. All necessary screws and instructions will be in the package. PS3 also can work with 1Tb HDD. Package looks like this: http://community.us.playstation.com/t5/i...
这个答案有帮助吗?
no you need a double HDD bracket or a 20 HDD bracket.
No1 liked Sony's idea creating a ps3 with flash memory (12gb) You can use and external hard drive but it will cost u money so...
I recommend u too use the cheapest bracket which is the 40gb i think . It's good for storing game file directories but not meant for huge games but still worth it .Dont worry if u have a low hdd on ur ps3. Other method is: Instead of bracket, u can use an 2.5 inch SATA drive, mostly found on pc or laptops,they vary accrording to their RPM. 5400 rpm is enough for ps3. For further help, use youtube
这个答案有帮助吗?
no acually a 50 gb bracket is the cheapest
How do I upgrade to HDD for more free space on PlayStation 3
这个答案有帮助吗?
you need to get a 20 gb hard drive and a new HDD bracket
As i said , you don't have to use SATA everytime u want to upgrade your hdd. U can use their memory drive and if it doesnt fit te ps3 hdd place , u have to use a kind of credit card(expired) or smth like that.i used my old pc storage and succeeded. Good luck!
这个答案有帮助吗?
yeah SATA is acually being replaced
Can use any 2.5" sata hdd also you need a hdd slim cage... find both on ebay!
Or you can use a bit of card top and bottom to hold the hdd in place. You must secure the drive so it cant move about.
Otherwise the hdd kind of floats held only by the sata port... not recommended as a slightest move of the ps3 can dislodge it!
See my vid about 3 minute mark. Whear i do this on a PS3 slim for an example.
这个答案有帮助吗?
A HDD 40 gb hard drive or disc is still not what you need you need a 20 gb hard drive or a new HDD but a new HDD is more money
这个答案有帮助吗?
I got a 160GB hard drive for 20 dollars so now I'll have 172 GB so altogether I put 85 dollars into my PS3 not bad and the games are cheap too there is a lot u can't play on the PS4 without streaming them for a
这个答案有帮助吗?
Yes, the hard disk drives are the same both on the PS3 and PS4. Also, the 2.5" SSD can be installed. But for real, there is very small difference in the game loading.
这个答案有帮助吗?
过去的24小时: 3
过去的7天: 17
过去的30天: 73
总计 63,597
well this answer technically and factually incorrect
由 jake graham 完成的
