跳转到主内容
加入维修社区 - 创建账户
第四代 Apple iPad(支持 CDMA 4G LTE 蜂窝网络,如 Verizon 版)的维修指南、拆解和故障排除信息,提供 16、32、64 或 128 GB 存储容量版本。于 2012 年 11 月发布。型号为 A1460。
How do I replace home button iPad 4
The home button on my iPad 4 (Verizon) only responds 30-40% of the time. It feel very loose compared to my iPad 1.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
6个答案
最有帮助的答案
The home button on the iPad four has a long ribbon cable that runs along the bottom of the digitizer to the left side of the iPad; it's several inches long and is a new feature that iFixit seems to have not acknowledged in this teardown.
这个答案有帮助吗?
得分 1
添加一条评论
iFixit totally failed to mention the ribbon for iPad 4 home button that is a new feature.
这个答案有帮助吗?
得分 1
添加一条评论
You should try calibrating it first, http://www.youtube.com/watch?v=b-HauFCb7..., if that doesn't fix it here is a teardown Guide so you can inspect the home button assembly and replace if necessary, good luck, If this answer was helpful please remember to mark it accepted
这个答案有帮助吗?
得分 0
添加一条评论
http://www.ebay.com/itm/for-iPad-4-iPad-...
ebay has them in stock! Check it out! Its from china but still better than nothing!
这个答案有帮助吗?
得分 0
添加一条评论
Try the fixes here! It says iPhone, but it also works on iPad too. Go to the link below. http://www.youtube.com/watch?v=yBfhCmq9V...
这个答案有帮助吗?
得分 0
添加一条评论
For iPad 4, all you have to do is to be careful when you are taking the screen off at the bottom and not to cut the ribbon. Everything will stay in place with no problem and you don't need to replace it. I have repaired a lot of iPad 4s so far with no issue.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Casey Wells 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 24
总计 5,824
