跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
iPhones 4S/No Service after battery replaced
I replaced the battery in my iPhone 4s (also unplugged the antenna when I did this), after replacing and reconnecting I plugged it back into iTunes and updated to 6.0.1 (At which point it said there are Carrier Update Settings for my iPhone, I clicked OK) and now I have lost reception completely and just says "No Service" in the top left corner.. My wifi works fine, Bluetooth works fine, everything seems to be OK besides my network reception. I have checked everything... took the phone apart again and checked the antenna connection, battery connection, checked the ground clip for the back panel, everything I had touched when replacing the battery. I also noticed that when I try a "field test" ( Dial *3001#12345#* ) it proceeds to the Field Test Mode at which point it just sits there with "Connecting..." in the bottom left corner and it WILL NOT connect no matter how long I let it sit there and do it's thing. I tried it with my old Iphone 4 and it gives me a readout even without a sim card.. I tried the 4S without a sim card and it still does the same thing, "Connecting...". I have since tried going to "Reset Network Settings" and even going as far as completely re-installing 6.0.1 in DFU mode several times, both without any success. Even tried with 3G On/Off, and turned Carrier Selection to Manual, no dice..
P.S. - I have also checked the "Blue Inductor Coil" and it appears to be fine as well. And I know the SIM is OK because I tried it in two different iPhones and it worked.
Any help would be appreciated... I'm going to order a new Dock Connector/Loudspeaker/Antenna cable and try it in the meantime..
Modem Firmware: 3.0.04
Firmware: 6.0.1 (10A523)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
9条评论
Hi Anthony,
Did you ever work out how to fix your no service problem?
I'm experiencing the exact same problem you have described above and wondered if you worked it out?
完成的
No I have not repaired this phone. It now sits in the cupboard as a part donor for my other iPhone 4S.
完成的
Have you reset the date on the 4s. It has probably set the date for 1972. If not then reset the date, lock in the date, remove the sim, reinsert the sim and it should work.
完成的
Wicked really thought i broke it thanks
完成的
thanks am happy for the answer may Allah reward u
完成的
显示更多的4条评论
添加一条评论
25个答案
已选择的解决方案
This is the just the problem of Correct date and time in your iPhone. This is the BIg problem of iPhone 4S . in every iPhone 4s if you take out the battery and place back, it will remain in searching . Change the date and time then restart your iPhone . if still have problem . Reset the network setting . your iPhone will work surely. Thanks
这个答案有帮助吗?
得分 36
28条评论:
Or Problem of Battery itself. Change the battery with Original battery .
完成的
I've tried everything mentioned.. The ground clip is fine. The date and time was fine so I set the date and time so it was not correct, reset the phone, set date and time again and reset again. Still doesn't work. Reset Network Settings without any improvement. I have noticed every once in a while that the phone asks me to activate it when I restart it sometimes as if it has never been used. Original battery is in the phone as well.. I'm confused as to why it isn't working
完成的
Had you restore it ?
完成的
The date and time thing worked with me. Good luck!!
完成的
Simran you are a genius!!! Changing date and time and powering on and off worked!! Thank you, Em x
完成的
显示更多的23条评论
添加一条评论
restore ur phone with itunes the problem will solved 99.9999999999999%
这个答案有帮助吗?
得分 2
1条评论:
it also worked for me after i have replaced the battery. I changed the date and time manually and restarted the phone, it worked perfectly. Thanks a million
完成的
添加一条评论
have you tried set correct date and time, then turn on airplane mode in settings then go to GENERAL THEN SCROLL TO RESET AND RESET NETWORK SETTINGS, WAIT FOR PHONE TO DO ITS RESET, THEN GO TO SETTINGS AND TURN AIRPLANE MODE ON AND THEN OFF AGAIN and watchfor search to find network. This has worked for me before. I would double check aenna grounding has been put back correctly under top screw of battery terminal.
good luck bob
这个答案有帮助吗?
得分 1
3条评论:
People could not call me nor text message me, a voice would say that they could not connect to the number. I´ve tried what you´ve said in your post Bob, and It worked for me, after battery change of my iPhone5S :-) Thank you so much
完成的
I have tried every possible solution posted here but my iphine 4s still has refused to get the netwak, keeps searching periodically and then No service appears. Just wondering what else i can do. connie
完成的
When i try searching manually ,it brings all other networks minus that of the simcard inside the slot
完成的
添加一条评论
Absolutely brilliant. Just changed the battery and couldn't see how I would have damaged any part of the phone when all it needed was the date/time /year changing. Thank you for your spot advice Simran.
Cheers
这个答案有帮助吗?
得分 1
添加一条评论
The problem is that you don't clean the pressure contact which creates wireless interference. You can see the step 5 on the iPhone 4S battery replacement page
这个答案有帮助吗?
得分 0
1条评论:
I have used a "q-tip" and dipped it in rubbing alcohol and cleaned the antenna contact, battery contacts, and the ground clip without any improvements
完成的
添加一条评论
When you take out the battery their is a little clip that goes under the top screw of the battery ribbon. It's some antenna ground. And we'll your in their check and clean the antenna connector.
这个答案有帮助吗?
得分 0
3条评论:
That is the wrong way to solve the problem, do as Thibaharan said and connect it to iTunes.
完成的
I've completely wiped the phone and re-installed iOS several times over without any gains. Stated earlier I restored it in DFU mode
完成的
If nothing work then you have to dismantle the logic board and put back properly .
完成的
添加一条评论
Maybe try this,
First, before you plug it into itunes or do anything go into your itunes account, go to the Preferences in ITUNES (it is located under the top lefthand corner) of the page. Go into your backup history, you will see a listing of every the date & time of the back up & restore attempts. DELETE all of them, rest your sync history.
Clearing out all of the previous back ups might help you, it might allow you to back up and restore the phone from itunes instead of a back up of the phones settings. Then try the clock and date change, turn off/on and see where your at.
Also, are you positive your battery is the correct battery for that phone?
Also charge the phone up to 100% before doing anything.
I would almost say that you have something somewhere either unplugged but it looks like it is plugged up. Disconnect all the connectors and make sure they are plugged in fully, one might have been bumped just a little lose. Check the OTHER END of the antenna
这个答案有帮助吗?
得分 0
1条评论:
Thank you,that helped a lot. :)
完成的
添加一条评论
Check the Antenna connection near the battery plug
After replacing the battery, forgot to check the antenna connection, after checking the cable that is loose, and after i plug it back, everyhting works fine
这个答案有帮助吗?
得分 0
添加一条评论
Error (1) is baseband, only thing you can try is reflow the motherboard. (In the oven for 2-3 mins at 180 degrees C). Good luck!
这个答案有帮助吗?
得分 0
添加一条评论
AWESOME - what great info Simon.
Switched time from manual to auto detect and turned off and on again and "searching had gone"
my symptoms were "searching" but 3G and calls were available.
JJ
这个答案有帮助吗?
得分 0
添加一条评论
No service or searching solution for when you replaced or reconnect the battery!
Reason is automatically set default time and date so screen is showing like no service or searching.
That's not an issue we have lot of ways just follow this any one method
1- Settings privacy location ON
2- connect to iTunes for two minutes
3- connect to wifi
No need to restore or format the phones.
Hope your problem will get solved more details contact me on what's app
这个答案有帮助吗?
得分 0
添加一条评论
The time and date are set to a previous year, it just confuses the phone, once you correct the time and date it works perfectly fine.
这个答案有帮助吗?
得分 0
添加一条评论
None of these worked for me. I reopened the phone and ensured the battery and antenna were properly placed, the cover degreased, the shield properly placed, etc. I had fixed the date/time, reset the network settings, restored iPhone from iTunes, left it connected to iTunes, tried toggling via WiFi and airplane mode. NO DICE.
HERE IS WHAT WORKED:
I chatted online with my carrier (AT&T). They had me read a couple of settings from my phone and sent a reset signal. BAM! Service.
If all else fails, but before fooling with your mother/logic board, contact your carrier.
这个答案有帮助吗?
得分 0
添加一条评论
My phone was stuck in "searching" after replacing my iPhone 4s battery so I attempted to restore it on itunes but now my phone is stuck in recovery mode and won't restore! Does anyone have any idea why this is? It seems to be a hardware issue seeing as it won't restore. Any/all advice would be much appreciated
这个答案有帮助吗?
得分 0
添加一条评论
i have the same problem its in emergency mode and when i type my password in it stays on the pasword screen and then goes black if you have any more info that would be great.
这个答案有帮助吗?
得分 0
添加一条评论
I have restored my iPhone 4S with DFU mode and it solved my problem.
这个答案有帮助吗?
得分 0
添加一条评论
I had the same issue with it showing Searching. The funny thing was that I could call and receive texts. Had to change my phone Time manually in General settings as suggested and leave the screen. Later I changed it back to Auto Set.
这个答案有帮助吗?
得分 0
添加一条评论
the date and time trick works v fine
这个答案有帮助吗?
得分 0
添加一条评论
Just wanted to say THANK YOU! I replaced my battery, got "searching," tried reassembling, cleaning, etc. and panicked! Reset the time and date and then reset the settings. When it restarted, all was well again. You guys rock.
这个答案有帮助吗?
得分 0
添加一条评论
How do you reset the date/time?
Mine is OK and the date time is in automatically-- it's also correct. Thanks.
这个答案有帮助吗?
得分 0
2条评论:
it is under settings. if it is correct then you are all set. when you unplug the battery it defaults to dec 31 1970
完成的
How do you manually reset year after battery change and before wifi comes up? Searching . . .
完成的
添加一条评论
Hi guys
Looking at this lengthy forum I've too had this problem after replacing with a new battery for my 4s!
I've tried everything even linking it to iTunes but no joy. I've been almost 5 days without calling signal only wifi.
I've been told by my network carrier that a faulty sim could be to be blamed! I'm going to try this otherwise IT will be a complete reset back to when I bought it again.
I think Apple must do something which must link up when things are changed etc. As now my silent switch is not working..... Spooky!!
这个答案有帮助吗?
得分 0
添加一条评论
worked for me thanks a heap!!!
这个答案有帮助吗?
得分 0
添加一条评论
I have tried the time reset option but then my phone just shuts back down. The battery is saying 100% charge but when I unplug it, it shuts back off to the apple screen.
Please help?
这个答案有帮助吗?
得分 0
1条评论:
Same here. Did you get solution?
完成的
添加一条评论
I have the same problem as Anthony. Wi Fi and everyting else but Carrier fine. Date toggled and now correct. With No Service showing, turn Auto off in settings for carrier selection and manually select a carrier. Indicator changes to Searching and a gray spinning beach ball appears to the right of the carrier selected. Indicator remains Searching until a Blue check mark appears beside the carrier selected. Simultaneous with the check mark, No Service reappears along with an error message that the selected cellular network is no longer available.
I get the same kind of error when I try using an old SIM card from another company that was replaced with a new smaller SIM when I upgraded my phone. In this case, I know that the SIM is turned off. So that is a clue about where the trouble lays. Its like the phone company itself is blocking the SIM. But with the ATT SIM that is giving me the No Service problem, I have spent hours online with ATT checking to make sure that the SIM is good by them.
I hope a fe more clues may help unravel this.
这个答案有帮助吗?
得分 0
添加一条评论
I have had a complete nightmare with this. Initially just the "searching" problem. So I tried updating the time countless times. Tried the flight mode thing on and off. Tried resetting the network. All multiple times. Nothing worked. Then went to iTunes tried to do an update but it wouldn't work due to some error. And my only option then was to restore to factory settings which also won't work. I can't believe that just changing the battery myself has led to this. Really frustrating. And I'm now left with all my data lost and having to buy a new phone.
这个答案有帮助吗?
得分 0
2条评论:
Aoife Ni Riain
You may be helped by going to a shop that changes iPhone batteries, they usually know exactly how to do this. If he opens your iPhone and take the battery out for a few seconds, he will check the wires and will do the right thing.
I had this done by someone here in Spain where we live, he did a good job changing the battery.
I hope this answer helps you, it´s cheaper to go to a small shop (no apple store, just mobile phones store who does batteries), than buy another phone.
Good luck, and please post if it helps you.
完成的
Thanks very much for your response. Unfortunately I'm living in a small village in Austria for the next few months so repair shops are limited and at least a train ride away. I purchased another phone on Ebay - not too expensive so just hope that works out! I don't think I'll ever try to repair anything to do with my iPhone again in future - will always pay for it to be repaired. It is not as straightforward as it should be. I thought changing a battery would be child's play. Thanks again for your response.
完成的
添加一条评论
添加你的答案
Anthony 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 77,601
