iPhones 4S/No Service after battery replaced
I replaced the battery in my iPhone 4s (also unplugged the antenna when I did this), after replacing and reconnecting I plugged it back into iTunes and updated to 6.0.1 (At which point it said there are Carrier Update Settings for my iPhone, I clicked OK) and now I have lost reception completely and just says "No Service" in the top left corner.. My wifi works fine, Bluetooth works fine, everything seems to be OK besides my network reception. I have checked everything... took the phone apart again and checked the antenna connection, battery connection, checked the ground clip for the back panel, everything I had touched when replacing the battery. I also noticed that when I try a "field test" ( Dial *3001#12345#* ) it proceeds to the Field Test Mode at which point it just sits there with "Connecting..." in the bottom left corner and it WILL NOT connect no matter how long I let it sit there and do it's thing. I tried it with my old Iphone 4 and it gives me a readout even without a sim card.. I tried the 4S without a sim card and it still does the same thing, "Connecting...". I have since tried going to "Reset Network Settings" and even going as far as completely re-installing 6.0.1 in DFU mode several times, both without any success. Even tried with 3G On/Off, and turned Carrier Selection to Manual, no dice..
P.S. - I have also checked the "Blue Inductor Coil" and it appears to be fine as well. And I know the SIM is OK because I tried it in two different iPhones and it worked.
Any help would be appreciated... I'm going to order a new Dock Connector/Loudspeaker/Antenna cable and try it in the meantime..
Modem Firmware: 3.0.04
Firmware: 6.0.1 (10A523)
9条评论
Hi Anthony,
Did you ever work out how to fix your no service problem?
I'm experiencing the exact same problem you have described above and wondered if you worked it out?
由 Stewart 完成的
No I have not repaired this phone. It now sits in the cupboard as a part donor for my other iPhone 4S.
由 Anthony 完成的
Have you reset the date on the 4s. It has probably set the date for 1972. If not then reset the date, lock in the date, remove the sim, reinsert the sim and it should work.
由 Martin Denny 完成的
Wicked really thought i broke it thanks
由 peter 完成的
thanks am happy for the answer may Allah reward u
由 katende Muhamadi 完成的
显示更多的4条评论
