跳转到主内容
The Droid Razr is an Android-based, 4G LTE-capable smartphone designed by Motorola.
60 个问题 查看全部
Can memory on board (16GB) be removed and accessed?
Hello,
can memory on board (16GB) be removed and accessed if one dismantles a Razr Maxx?
Can the 16GB SanDisk NAND flash chip (SDIN5C1-16G) be removed and plugged into some sort of reader?
Thanks!
~Frost~
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
Scott Luckman, yes there are NAND Flash memory readers that are commercial available. Places like this have them for `$200 + cost for the software Here is another model. Or you can go all out and build your own, by following this link. So, is it possible, absolutely, but it will require plenty of resources...:-)Hope this helps, good luck.
这个答案有帮助吗?
得分 1
1条评论:
Thanks old turkey! Plenty of resources indeed. Software appears to be of great value here. Thank you for the info, much appreciated. Quite astonishing how this embedded NAND is so difficult to read post mortem. I wonder if the engineering is intentional so when a dead phone is found it is not accessed with ease? Essentially if i read correctly it is a flash chip in essence without the built in (firmware?) consumer chips employ? Fascinating puzzle.
完成的
添加一条评论
添加你的答案
Scott Luckman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 5,523
