跳转到主内容
The Chevrolet Cavalier is a compact automobile produced from 1982 to 2005 by General Motors.
139 个问题 查看全部
2001 cavalier wire problems?
my cavalier has been a lil screwy since i replaced the radiator, my speedometer, gas gauge, and car temp gauge always read zero while i drive, also all the egine lights pop up while im driving as well, also my license plate keeps going out randomly is this a fuse problem? or something else?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Jordan Lewis, it's to complex to be fuse issue. Double check all the wiring under the hood to make sure you did not accidentally loosen or disconnect and of the harness connectors. Your errors sound like a bad instrument panel. As for your engine light, I would start by taking to a place where you can get the OBD scanned. Autozone does it for free, and it will give you a better starting point. Here is a decent write up on how fix the instrument cluster. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jordan Lewis 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 5
总计 3,330
