跳转到主内容
Model A1297 / 2.66, 2.8, 2.93, or 3.06 GHz Core 2 Duo processor
1004 个问题 查看全部
Screen replacement: is LP171WU4(TL)(A4) LCD compatible with (TL)(A3)?
I have a 17" Macbook Pro (early 2008, A1261), and am in search of a new LCD screen replacement. My LCD is LP171WU4(TL)(A3), matte, 1920x1200, LED.
Found a deal on a LG's screen similar to what I have, LP171WU4(TL)(A4), but the part number suffix is slightly different (A4 vs A3). It is also glossy instead of matte. The other specs are the same, 17" 1920x1200 WUXGA, LED.
Is this compatible with mine? Any help would be greatly appreciated. Thanks in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
james32, I just reviewed all the specs for both panels. The only difference I can find is the Hard coating(2H) Anti-glare treatment of the front Polarizer (Haze 44%) for the LP171WU4-TLA3 and Glare & Low Reflection treatment of the front polarizer (2H) for the LP171WU4-TLA4. Every other data spec, as well as connectors, are identical. The datasheets for the panels are available right here. Based on that, I surmise that the panels do interchange. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
2条评论:
Hi oldturkey03, these datasheets are very helpful. Thank you so much for your help!
完成的
you are very welcome. Best of luck to you.
完成的
添加一条评论
添加你的答案
james32 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 1,001
