跳转到主内容
加入维修社区 - 创建账户
2006年11月, Wii 在北美市场发布。这是任天堂第一款支持直接连接互联网的电视游戏主机。该主机支持在线游戏,以及通过 Wii Shop Channel 分发数字版游戏和媒体内容。
Will not turn on with red power light
I've been having issues with my Wii where the red power light is illuminated but the console will not turn on. I tried doing an AC Adapter reset and that didn't work. I checked the DC voltage and it's just over 12V like it should be. So then I followed this guide to reseat the bluetooth card but no dice. Then I read somewhere on how to do a bench test by taking one component off at a time and checking power. After resassembling the console I started over and too my behold I found that applying power after removing the optic drive made the light go from red to green. My question is, is this a safe solution to my issue? Could the red light be due to a bad optic drive?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
4个答案
最有帮助的答案
vinnylastella, great way of trouble shooting. I would most certainly start by replacing the optical drive and re-evaluate from there.
这个答案有帮助吗?
得分 1
添加一条评论
Hi i think this could be more of a loose connection issue, because when you say that you have to apply pressure on the optic drive in order for the wii to work then most likely the issue is located somewhere in that area or underneath the area, so open up, check for loose connection again, and try, always triple check cheers!!
这个答案有帮助吗?
得分 0
1条评论:
Actually I ordered a new optic drive from Newegg.com just on a whim that that was the issue I was having. I got the new drive in yesterday and I installed it this morning. Everythings working again. I guess the bench test procedure I used worked out. Thanks for the input. I'm an electrician so I know the importance of repetative checking. >.<
完成的
添加一条评论
I wanted my power to turn on so i can play
  1. * Hit <enter> to insert another list item, and <enter> twice in a row to end the list. To get subitems, repeat the bullet character once for each level of indent you want (e.g. ##)[http://nintendo|nintendo]
这个答案有帮助吗?
得分 0
添加一条评论
Hi, I am interested in this bench test procedure. Is there a resource where I could find a step-by-step instruction?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
vinnylastella 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 32
总计 4,882
