跳转到主内容
Capturing high-quality digital images is fast and easy with this state-of-the-art smart camera. Equipped with a 14.0-megapixel CCD, this camera is capable of capturing images with a resolution of up to 4288 x 3216 pixels.
How to delete photos on camera disc
how do I delete images on camera w/o replacing disc
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
thomas Riley, that should be part of your menu.
"Erasing Images
Erasing a single image / Erasing all images
1. Press the 7 button.The last image appears on the screen.
2. Select the image you want to erase with the < / > buttons.
3. Press the MENU button.
4. Select [Delete] with the up /down buttons, and press the SET button.
5. Select [Single] or [All] with the < / > buttons, and press the SET button.
[Single]: Erases the selected image or the last image.
[All]: Erases all of the images except for the protected images.
6. Select [Execute] with the < /> buttons, and press the SET button.
To not erase, select [Cancel], and press the SET button.
7. To exit from the menu, press the MENU button.
The manual is available right here
Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
thomas riley 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 1,487
