跳转到主内容
加入维修社区 - 创建账户
Microsoft Surface 系列平板电脑的维修手册和信息。
Broken glass on Microsoft Surface
Do you know where I can buy a replacement glass for the Surface ? The glass is cracked but the screen is ok, I can still use it...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 19
3条评论
how i can buy a Surface rt glass ? The glass is braked but the screen is still working , I am still using. i am looking for best way how can i buy it, in U.A.E quite difficult to find Surface parts.
完成的
there are a string of posts all asking the same question, where to buy the screen components.
it seems no one has the answer, so what is the point of this forum then?
we have the usual blind chasing the blind.
完成的
Hello, we just bought a Microsoft Surface Pro 3 1631 LTL120QL01 12" LCD Touch Screen Digitizer AssemblySurface Pro 3 screen from Ebay "China" with free expidated shipping.
I wil llet know the quailty of the item.
完成的
添加一条评论
8个答案
最有帮助的答案
http://www.mylcdtouchscreen.com/
Sells just the glass for a good price
这个答案有帮助吗?
得分 3
添加一条评论
Mike Asseraf, "LCD and glass are fused together" from here . This usually means that it is almost impossible to replace one without the other. Check on here for a replacement. Still costly but the only ones I found thus far.
这个答案有帮助吗?
得分 1
1条评论:
So I have somewhat the same problem. By boyfriend stepped on my tablet cracked the screen but the screen is not functioning :( if I purchase the replacement for the screen and lcd would it fix my problem? Would it work 100% properly? Please answer ASAP I was going to purchase this today.
完成的
添加一条评论
I'm not sure that you will find in the internet anything. Because the surface is new the only way to find spare parts as the glass you should take your surface where you bought it.
这个答案有帮助吗?
得分 0
1条评论:
Yes, I know it's hard but I don't have the choice... I live in Israel, bought my Surface in New York... And the only option I have is to pay $300 to Microsoft to have my Surface replaced... But when you live 8000 km from the store it's quite difficult :) So iI must find a way to buy the glass and have my Surface repared in Israel.
完成的
添加一条评论
Mike -
I am looking to replace my Surface glass also. I saw your post and just want to tell you that I wish you and all your countrymen THE BEST!!
I could never understand the hardships you and/or others must be facing now - physically, emotionally, locally amd abroad.
What I can tell you is that the media does not reflect the majority of Americans. WE STAND WITH ISRAEL ALL THE WAY!!!!!!!!!!!!!!!!
这个答案有帮助吗?
得分 0
添加一条评论
Oh my! It's my problem too. If the glass screen is cracked & it is still functioning well, is it possible that the LCD may be affected too? I'm in the Philippines & the gadget is from Australia.. What should I do?? :(
这个答案有帮助吗?
得分 0
2条评论:
have you found a solution to your problem? I have the same exact problem. My surface pro 4 glass cracked and I need to have it repair but I also live in the Philippines.
完成的
I have the same problem! I accidentally dropped it on concrete and it cracked :'(
完成的
添加一条评论
Is there anyway to replace the screen without replacing the whole thing , in malaysia
这个答案有帮助吗?
得分 0
1条评论:
hi Andrew we all have the same problem, based on my research you can purchase your replacement surface pro screen at aliexpress.com
完成的
添加一条评论
这个答案有帮助吗?
得分 0
1条评论:
of couse you can, here is the lcd i found on google search result
完成的
添加一条评论
ciabate@gmail.comhi there l want a new placement glass for my 7 touch screen andriod tablet
Update (11/06/2017)
could you send a free 7 touch screen andriod tablet in the post my address his flat 108 twinnell house stapleton road easton bristol from mrs marcia bate
这个答案有帮助吗?
得分 0
1条评论:
cold you plase send the 7 touch sreen andriod tablet urgently in post to flat 108 twinnell house stapleton road easton bristol
完成的
添加一条评论
添加你的答案
Mike Asseraf 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 26
总计 33,476
