跳转到主内容
The first generation Honda CRV, produced from 1995 to 2001.
20 个问题 查看全部
Car will not start but has power
The car will not start but does have power. What could this be?
Thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 11
22条评论
There are hundreds of possibilities. what does it do? Does it crank over? Do you have spark at the spark plug? Ford it get fuel? Did anything happen to it prior to? Did you have the service engine light on? What have you tried so far? the more information you can give us, the better we can help you.
完成的
It tries to crank but just wont start. The check engine light has not been on. Spark plugs were looked at but not sure how to check them. The day before this happened there was a loud screaching sound when I tried to start it then a noise as if something went from front to back underneath. (I thought it sounded like a stick or something that had gotten stuck)
完成的
You say it "tries to crank" does it turn over? Did your car stall when you heard the loud noise?
完成的
The car did not stall whith the noise and it started back up the next morning. It sounds like it normally does when I try to start it, it just wont start. I guess that would be turning over.
完成的
could it be a belt? if so which one?
完成的
显示更多的17条评论
添加一条评论
6个答案
已选择的解决方案
Mandy, you could just have a bad main relay. The main relay should be under the driver's side of the dash, by the brake pedal. The Blue/White wire powers the fuel pump. When the key is turned on, the Engine Control Module will ground the Green/Yellow wire for 2 seconds so the fuel pump will operate. If there is no or low voltage on the Blue/White wire, then verify that the White/Black wire has good battery voltage. Also, make sure to check the check the Black wire for a good ground. Check fuse number 9 in the under-the-dash fuse box.
这个答案有帮助吗?
得分 7
5条评论:
Will do. Again, thank you so much
完成的
How check voltage on that ? Above question. W Mandy
完成的
Oldturkey03 you are correct however I believe I found the solution. Once your battery is good simply do this. This may seem silly but it worked for me. Disconnect your car battery, go to you fuse box located under the steering wheel and use a thin flat head screw driver or pliers to remove all the relays one by one and resit them. To use the flat head screw driver, pry it at the bottom of relay and force it out. Strange enough it fix the starter problem. Be aware that the blue relay was not move. Reconnect the battery and try starting again.
完成的
the car ill run after replacing the ecm for a couple weeks but then does the same thing again and wont start and not getting spark. Do u think it could be something with the distributor?
完成的
Saya punya CRV THN 97 jika sudah panas, susah dihidupkan
完成的
添加一条评论
I have a 97 Honda crv it want start up at all it turns over i replaced the starter and gas pump and i checked the distributior changed spark plugs a new battery and i am lost i need some help please
这个答案有帮助吗?
得分 3
1条评论:
I have the same problem. Except mine died along the highway. It put out smoke then backfired then died . It started up shortly after then about the same place along my rout it would recur each time taking longer to restart. Now it stays inoperable a few hrs then resets. I'm stumped I've replaced the fuel filter and air. I was thinking battery ?ignition ? Senser of some sort ? Or relay ? Does it have an obd?
完成的
添加一条评论
I had a similar problem with my 2001 Honda CRV that ended up being the ignition control
Its in the bottom right of the distributor cap. $45 part
module
这个答案有帮助吗?
得分 1
2条评论:
I replace the ecm in my car and it runs good for a couple weeks and then all of a sudden stall or wont restart and has no spark again. if i replace the ecm again it will be fine again for a little what could be causing this? Would be be something in the distribute its self>
完成的
Thank ú for the brief yet accurate photo and information! I believe that may be my issue.
完成的
添加一条评论
From Kiribati my request based on honda GF-RD1 does not start.
这个答案有帮助吗?
得分 0
添加一条评论
Have a Honda CR-V 2001 changed fuel pump sounds like it wants to turn on but wont
这个答案有帮助吗?
得分 0
1条评论:
From Papua New Guinea my 97 crv rd1. Crank but not start, please I need help.
完成的
添加一条评论
I have a 2000 Honda CRV 2.0 l 5 speed and we just did a clutch replacement and now for some reason it's not starting and we're trying to figure out why and the starter wire is on and tight. For some reason whenever we go to push down on the clutch pedal it just stays on the floor we have not blood the new one yet can't get it started to bleed it
这个答案有帮助吗?
得分 0
1条评论:
Hi Robert,
I've never seen a manual transmission clutch that required the vehicle to be running in order to work. There's no reason you have to start it to bleed the clutch.
Are the safety interlocks in place and working? Most cars require either the transmission to be in neutral or the clutch to be depressed in order for the starter to operate, so check the neutral start switch and/or the clutch switch (if present)
完成的
添加一条评论
添加你的答案
Mandy 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 19
过去 30 天: 64
总计 79,652
