跳转到主内容
加入维修社区 - 创建账户
型号 A1213或A1218,闪存容量:8、16及32GB
Power Button Broken - Gold Spring.
Hello,
Have been restoring my ipod back to its original condition (hardware) - After this the gold spring from the power button has broken off.
I cant find any reconstruction guides of this online, so i ask what would be a fix for this? (Not buying a new panel)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
William Briggs, the spring connects the communications board with the power button. depending where it is broken, you could try to resolder it, or you will have to purchase an old broken iPod to harvest it.
这个答案有帮助吗?
得分 2
2条评论:
Ohh so its only soldered on? If it is, that's ok for me to fix :) I thought it was spot welded on or something stupid :D
Thanks - Will
完成的
It is soldered. Apply some solder on the board, some on the spring and then solder the pieces together :-)
完成的
添加一条评论
添加你的答案
William Briggs 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 648
