跳转到主内容
The Roomba Red 4100 is a vacuum cleaner robot produced by iRobot that can clean a room all on its own.
12 个问题 查看全部
Keeps Circling In Same Area
Keeps circling same area over and over and then stops. Battery is still charged. How do I correct this problem? Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Diane, this can be caused by dirty or defective bumper sensor as well as dirty cliff sensors. Clean the Roomba with compressed air and "slap" the front bumper. Apparently, the front bumper mechanism can get stuck with any contact with a wall etc. which will make the Roomba back up. Use these guides to work on your Roomba. Check on here for more information as well. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
1条评论:
Did the trick thank you!
完成的
添加一条评论
添加你的答案
Diane 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 31
过去 30 天: 37
总计 10,289
