跳转到主内容
加入维修社区 - 创建账户
型号 A1237 或 A1304 / 1.6、1.8、1.86 或 2.13 GHz Core 2 Duo 处理器
Single Beep No Boot. RAM issue?
The MacBook Air was was working perfectly fine when suddenly the screen froze and I had to do a force shutdown. After that when I tried to boot, I got a Single Beep with intervals of ~5 seconds. If I press and hold the power button, the light flashes continuously for 4 seconds and then it beeps.
The screen is blank and there is no processor or hard drive activity while it beeps.
I have tried the 'CMD+R+P' and press and hold 'D' boots without any success.
This is most likely a RAM issue but since the RAM is soldered on, I cannot reset it as most guides have mentioned.
This is what the motherboard looks like: http://imgur.com/a/ZYy1l#0
Any help would be really appreciated.
Thanks in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
5条评论
Whatever happened with your computer? I am experiencing the same thing, and anticipating the worst.
完成的
Try to disconnect the battery if it is possible on the MacBook Air and press the power button for about 30 seconds with battery and power adapter being removed - this will reset all capacitors within the book and RAM is a kind of (very basically).
If this does not bring any success I think the RAM is bad.
Regards, Stone
完成的
Hey all if it is beeping it's the ram.
Remove the main board
Use a heat gun to heat up the ram on the back and the front
Let the board cool
Done! Worked for me
完成的
I've had this problem and searched high and low - and despite warnings by 'professionals' to throw the Macbook Air away - I took one long last approach to clearing what was probably a moisture contamination issue on the mother board - Simply remove the Main motherboard - then clean it carefully with a solvent using cotton bud swabs, then into the oven at 190deg C for 9 minutes - and hey presto it came back to life perfectly. Trust me this is scientific.
完成的
heat gun from both sides helped me as well!!! don't be afraid, I put the gun quite close (3cm/1inch) and kept it until I count to 10, then other side and repeat until I was able to hold the board on the edge. Nothing was melting and I didn't believe it would help, I was prepare to put the board on my shelf as decoration, but it really worked! I'm so happy (-:
完成的
添加一条评论
4个答案
已选择的解决方案
Yes--according to Apple one beep means no RAM installed. Link provided.
http://support.apple.com/kb/HT1547
这个答案有帮助吗?
得分 3
添加一条评论
I have the same issue. DId you manage to fix your Macbook Air in the end?
这个答案有帮助吗?
得分 0
添加一条评论
Thank you! It works!!!
I took the mother board out, took off all rubber and plastic protections, put it in the oven at 190 Celsius degrees for 9 minutes, as NIck Justice suggested.
It works!!! My MacBook Air came back to life!
Some tips… I used some crumpled paper (like small balls) to avoid the board touching the oven tray. I also let the oven get to the right temperature before putting the board into it.
这个答案有帮助吗?
得分 0
添加一条评论
Hello everyone! Thank you very much to Nick Justice and andregrillo.
The first time I cleaned the logic board using isopropyl alcohol in the region of the RAM chips, applied solder flux and tried to heat it up with the heat gun. It worked, turned on and stayed on for about 5 minutes, then it turned off again, returning the beeps.
In a last attempt I decided to try to put it in the oven as you suggested, I left it there for 13 minutes at 180-210 C.
Worked perfectly! I've been using it for 1 day, and I haven't had any more problems!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
fence2012 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 12
总计 24,037
