跳转到主内容
第六代 iPod classic 。机型型号 A1238,80/120/160 GB 机械硬盘,黑色或银色金属前面板。
My iPod will only play through one headphone?
I have a 160 GB iPod Classic, bought just over a year ago... so, the warranty is no longer in effect. Basically, my headphones jack is messed up. Sound will only come out the left ear. If I press the headphones against the left side of the jack it will play correctly, but I have to hold it there in order for it to work. Is this fixable? Or should I just go ahead and buy a new one?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 13
1条评论
I replaced my battery on my Classic and now get one ear sound and my hold button no longer works. Help!
完成的
添加一条评论
5个答案
已选择的解决方案
Sasha, it is absolutely fixable. Replace the audio jack. Follow this guide. The part is available at multiple places, depending on your geographic location. Hope this helps, good luck.
这个答案有帮助吗?
得分 4
2条评论:
It's nothing to do with the jack, I took mine in to an Apple Store and tried it with there brand new beats and it still only played out of one ear. It's an iPod fault.
完成的
@sonofshanx you are absolutely right. that is exactly the jack that is in question. The jack on the iPod not the headphones...clearly described in the answer
完成的
添加一条评论
最有帮助的答案
I had the same problem with an Ipod and the advice I found online wasn't really helpful. I found that the jack wasn't making contact with one of the pins inside the jack socket. I took a small flathead screwdriver, inserted it and twisted it to raise the contact pin. It worked fine for me. Hope it helps!
这个答案有帮助吗?
得分 5
4条评论:
I got the exact same problem, I wish I could see a pic of what pins you're talking about.
完成的
(For the 160 GB ipod) If you look inside the headphone jack there are two gold prongs. One on each side. I just used a pent staple to pull the one on the side that wasn't making contact and now it's playing through both sides again. (It wasn't working on the right side, but now plays perfectly with my headphones and my speaker in my office.)
完成的
I did this with a phillips head screwdriver and it worked. I could see the volume level going up and down as i turned the screwdriver.
完成的
Add a quick toothbrushing with some ipa 91% and poof. like brand new. Dental pick makes easy work of this project.
完成的
添加一条评论
My iPod 4 only worked on right speaker with headphones . This is how I fixed it in the following steps:
Settings
General
Accessibility
Hearing
L) & R) should be in the middle of scale.
这个答案有帮助吗?
得分 3
3条评论:
Thank you so much, Chrissy! I was all set to restore my iPod Touch to factory settings when I came upon your advice. I followed your directions and sure enough, the L & R speakers were not in the middle for some reason. Problem solved!
完成的
My ipod Classic 160 doesn't have a 'General' under 'Settings'... what to do?
完成的
pls. reply
where can i found the new replacement accessories???
& the tool kits???
完成的
添加一条评论
Great advice from chrissytt:
"My iPod 4 only worked on right speaker with headphones . This is how I fixed it in the following steps:
Settings
General
Accessibility
Hearing
L) & R) should be in the middle of scale."
这个答案有帮助吗?
得分 1
添加一条评论
pls. reply
& the tool kits???
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sasha 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 44
过去 30 天: 223
总计 77,462
