跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
915 个问题 查看全部
问题已关闭
iPod touch 4 mother board
Hi,
How can I know how many gigabytes has my iPod touch's mother board? It has a number: 820-2944-A
Thank you.
Regards Atti
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论:
I found this to see if someone will help: The capacity of a 4 and 5 of the sign code. For example:CG-8Gb
DG-16Gb
FG-32Gb
HG-64Gb.
完成的
Well that would make yours a 64 GB:-) can you link to the source of the information?
完成的
Looks like the right information, great find :-)
完成的
添加一条评论
2个答案
Attila, it is almost impossible to tell you that from the motherboard number. The best way would be if you check the number on the Toshiba NAND memory chip itself. You are looking for something like TH58NVG6XXXXXX
这个答案有帮助吗?
得分 0
1条评论:
Hi,
Thank youu for your answer.
It has a Samsung memory chip. K9UHG08U8M-LCB0
完成的
添加一条评论
That motherboard part number is for the 32gb.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 855
