The power pin on the DC jack has been loose and will not charge my battery. Is there a way to fix the pin so that the plug will transfer current, without getting a replacement?
Rishi, the only way you can fix it properly is by replacing the jack. You do want to make sure that it is still properly soldered onto the mother board. If it is loose, you may solder it back on, if it is the jack itself, you will have to replace it.
