跳转到主内容
2006年十月在北美发布(然而2021才翻译。。15年的坑)
286 个问题 查看全部
Wii Click of death.
My Wii is a few years old and has decided to CoD (Click of Death) http://en.wikipedia.org/wiki/Click_of_de... any time ANY disk (GC or Wii) is inserted. it still spins. but won't read. this did not happen suddenly. at first it would not read certain disks sometimes, then it wouldn't read most disks sometimes, then it wouldn't read any disk, and now, it wont read the disk and brings up the Wii's BlSoD (Black Screen of Death). Is the disk drive repairable or is it time to swap disk drives or is the Wii cooked with a side of mashed potatoes?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
laz is not dirty, i think it's time to set the dinner table...
完成的
添加一条评论
5个答案
最有帮助的答案
Superchu, sounds like the laser is either dirty, may want to try to clean it, or "cooked with a side of mashed potatoes" . Most likely it is time to replace the drive.
这个答案有帮助吗?
得分 3
添加一条评论
You can pick up a replacement drive on Ebay for about $20-25 dollars. Fairly easy to do yourself as long as you have a tri-wing screwdriver also found on ebay cheaply.
这个答案有帮助吗?
得分 2
添加一条评论
Superchu did you figure out what it was by any chance? My Wii is clicking too and everytime I put a disk in it try's to read and then a page pops up saying eject the disk and restart the Wii and check the manual troubleshoot guide. So if it was just the lazer that is awesome but if it is the disk drive it would be nice to know so I can just get it out of the way. My 6 yr old wants on there badly and I feel bad not having it fixed yet. Thank you for any help you can give!!!!!
这个答案有帮助吗?
得分 0
1条评论:
Mine is doing this same thing....... what was the conclusion?
完成的
添加一条评论
Ordering new drive for mine
这个答案有帮助吗?
得分 0
添加一条评论
I had this same problem. First time it happened, I replaced the entire drive. Then it happened AGAIN, but this time I noticed that one of the little helical gears had split and detached from its shaft. Someone kindly posted a ctb file of the gear, so now I'm trying to 1) convert the file to stl or something more common and 2) find a 3D resin printing service who would make 2 or 3 of these for me.
https://www.reddit.com/r/consolerepair/c...
I'll also be adding a screw to hold the shaft in place, as mentioned in this post.
https://github.com/BiegunskiEr/Wii-Disc-...
Replacing a tiny piece feels so much better than replacing the entire drive.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Superchu 将永远感激不已
浏览统计数据:
过去 24 小时: 9
过去 7 天: 25
过去 30 天: 136
总计 16,276
