Brake lights constantly on and truck wont shut off without pulling fus
Brake lights constantly stay on and now engine wont shut off without pulling brake light fuse what causes this to happen?
scott, check the under-the-hood fuse panel. Check the brake light relay, I bet it is stuck. It is right next to the starter relay and I would suggest that you check the box for corrosion and short circuited wiring. Check the wiring harness going to the box as well, make sure there are no bare wires etc. Of course, also check the brake light switch. It connects via a plunger to your brake pedal.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 623
