跳转到主内容
加入维修社区 - 创建账户
Inspiron 1545 于 2009 年 1 月 16 日发布,是一款 15.6 英寸的入门级个人笔记本电脑,提供 3 GB 或 4 GB 内存版本。它是 Inspiron 1525 的继任机型。
How do I bypass the password authentification system?
When i turn the computer on, it says "this computer system is protected by a password authentification system . You cannot access the data on this computer without the correct password". I did NOT put this on here! How could this have happened, and how do i get oast it so i can use my own computer again? Please help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 57
23条评论
bY PASS THE PASSWORD AUTHENTIFICATION SYSTEM HOW SOLVE PROBLEM
完成的
don't have reset disk bought this at savors it got donated without anyone being told of the password how can I bypass this
完成的
had this problem on a work computer...Dell Opti 9020. We don't use this feature so it should not have come up...Contacted Dell, and they generated a password...Will probably verify ownership though.
完成的
go to bios-pw.org, get your password by entering the code/serial tag, if control+enter doesnt work, press left control+enter twice
完成的
i have dell inspiron 1545 it pop-up a sreen saying this computer system is protected by a password authentication system how can i bypass it . by dj-sn@cks
完成的
显示更多的18条评论
添加一条评论
10个答案
已选择的解决方案
Heather, there is no way of bypassing it. It is the BIOS password and can not simply be bypassed. You can check on the Dell support site and try to follow those instructions. Anything else, you will have to call Dell and see if they can issue a standard password, based on your computers models number etc.
这个答案有帮助吗?
得分 31
11条评论:
I have a Dell latitude d630 and I have the same problem, how can you bypass this!
完成的
Hola tengo el mismo problema con una dell latitude E 7470. Etiqueta de servicio #GWBJLC2
完成的
You used to be able to take the battery and the CMOS battery out and it would reset.
Not sure on these Dells though - Oldturkey seems to know his stuff ;-)
完成的
Nothing like computer geeks... You guys are the best... Nerd on forever
完成的
Well this man walked me through my Imac LCD display problem, and during the holidays yet. This Imac girl, the one with all the wrong screens . Well it took me all this time to find the right one for the right price. Still need one more, and have 3 to sell. Any way i just wanted to thank you so much for helping me out. So everybody out there, he knows what he's doing, so listen to him he's great.
Lynn
完成的
显示更多的6条评论
添加一条评论
For those, whom are stucked, perhaps can try this
https://bios-pw.org/
这个答案有帮助吗?
得分 21
17条评论:
@ Augustine
Yea, I tried that link but didn't work for me. ,Dell inspiron 1440.. #CKXXKJ1-595B, is protected by password authentication system,,,
完成的
I went to that site and it ask for a code. What's the code?
完成的
After trying all the codes generated I noticed tiny print below them. Press CTRL + ENTER. The second code generated by that link solved my gumbo-lock. Thank you very much. BTW folks if this 55 yr old woman can do it so can you.
完成的
Gracias... muchas pero muchas gracias, me sirvió ... este es el modelo de mi laptop:
DelI Inspiron 1420 series
El sistema mostró varias opciones de contraseña, la segunda fue la correcta.
完成的
Thank you, Augustine. Worked for me twice; each time required Ctrl + Enter, (Enter was the only instruction given on the unlock screen); each time it was the code next to "Dell from serial number" that worked. By the way, the code the site asks for is the serial number with the four character extension that shows up on the unlock screen where you're asked for the password.
完成的
显示更多的12条评论
添加一条评论
Go into the bios, and go down to security and select system password and it will say type in password and press enter twice and it will remove the password
这个答案有帮助吗?
得分 3
8条评论:
the software does not allow me to get to the bios, or anything else just the page asking for the password the authetication system.
完成的
bronzen1, what model computer do you have and what have you tried?
完成的
Same thing happened to me...used F8 on reboot, accessed set up utility, reset a new password and now.....stupid authentication screen! Not crazy about messing with cmos batery ....
完成的
burn your computer to the ground that should do the trick
完成的
mine is doing the same thing and it sucks idk how to get into it!!!
完成的
显示更多的3条评论
添加一条评论
It seems like a BIOS password and the best way to reset BIOS password is to take the motherboard backup battery apart. Simply just take out the small battery out and leave it like this for about 10 mins and then put the battery back inside the slot then power on your PC this shall remove the any BIOS password.
这个答案有帮助吗?
得分 2
2条评论:
I don't think removing the battery deletes the password. It does delete other settings.
完成的
#5634mj1-1f5a,
完成的
添加一条评论
Go to: https://biospassword.eu/dell-free-passwo...
enter your service tag
enter the generated password press ctrl, enter, enter
Thank me later
这个答案有帮助吗?
得分 0
2条评论:
I'm locked out and my keyboard and mouse arent are!! I'm lost as to what I can do?
完成的
Thanks so much, it worked
完成的
添加一条评论
Solution is very simple you have to crack the password, Its really easy.
Go to this website enter the code which is showing in your pc and generate a new password.
Enter it and you are done.
https://okadtech.com/this-computer-syste...
This will help you to do it step by step.
Hopefully this will help you.
这个答案有帮助吗?
得分 0
添加一条评论
I have a problem with the bios password for the SSD hard disk. I want to solve the problem. The error code is 010704637HP-2A7B.
这个答案有帮助吗?
得分 0
3条评论:
@gameapk this is not going to work for your drive. I don't think there is a hack for an encrypted drive.
完成的
I want a solution for that
完成的
I did not create any password
完成的
添加一条评论
To bypass that password simply open the casing, locate the jumper wire on the main board labeled pswd, disconnect and restart computer. Easy peasey.
这个答案有帮助吗?
得分 0
添加一条评论
#5634mj1-1f5a,
这个答案有帮助吗?
得分 0
添加一条评论
THIS is why you SHOULD have a BIOS p/w on any computer that others may have access to.
Because, if you didn't put the password in, someone else did because there was no password needed for them to do it.
HOWEVER, now you must remember the password somehow. I highly recommend a password manager. Bitwarden free works well for me.
这个答案有帮助吗?
得分 0
1条评论:
I can't set the system password
完成的
添加一条评论
添加你的答案
Heather 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 40
过去 30 天: 177
总计 172,406
