跳转到主内容
加入维修社区 - 创建账户
2.3L 4cyl or 3.0L V6, 6th Generation
cooling fans won't work
fans not working, fuses are not blown, and tried to jump start from battery but still didn't work
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
You tried to "jump start" the fan directly from the battery? It still did not come on? Can you tell us how you did that?
完成的
When my turn on my a/c the fans work but if I turn the a/c both fans turn off can somebody help me on this
完成的
添加一条评论
2个答案
已选择的解决方案
dominic, if you connected a positive wire to the blue or blu/blk wire and ground to the blk one, the fan would have to come on. Of course only if connected it directly. If you did not then there is the possibility that you have a bad fuse #3 and #57 for the cooling fan and #58 for the condenser fan. You also want to check your fan relays. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
添加一条评论
This is a great help!
Can I swap the two identical-looking relays -- the one for the condensor fan and the one for the radiator fan -- to check if they are both working without causing any damage? The radiator fan comes on but the condensor fan does not. Trying see what I need to replace.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
dominic 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 67
总计 31,835
