跳转到主内容
This is the first generation of the Ford Escape, a compact crossover SUV. Production started in 2000 for the 2001 model year.
Jump past the front side window button to get window up?
Window will not go up on passenger side window. I would like to know how to take the side panel off and jumper past it. What contacts do I use? All the other windows work fine. It is just the button on the door panel. The button will take the window down, but not up.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Just bridge the contact on the switch and see if it moves the window up
完成的
添加一条评论
1个答案
已选择的解决方案
williamsk, this video should get you started., Still checking on the diagram about which contacts to use. You should get away with trying the ones on your switch first. Also, check all your fuses and make sure your lock switch is in the unlock position:-)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
williamsk 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 643
