跳转到主内容
也称 PS2 ,是索尼于2000年3月在日本首发的第六代电视游戏主机。当年稍后时间登陆美国市场,机器型号为 SCPH-30000。维修这款设备只需用到常见的工具,但维修过程可能会有点难度。
20 个问题 查看全部
Why has my screen changed to black and white
For some reason the playstation 2 is in black and white only. We tried to plug something else into the connection on the TV and it was fine but the playstation is still only black and white.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 10
7条评论
i have a similar problem with my ps2, however I bought a aftermarket cable, would this cause it to show black and white?
完成的
after playing game for sometime by pendrive graphics become un-understandable why???
完成的
Thanks a bunch, it works!
完成的
I have this problem, but I have the slim version, is there a difference? and I have a weird tv, that does not have the normal yellow, white and red holes for the cables, but video works, and sound just fine, but no color.
完成的
Everytime i play f1 2006, richard burns rally, and a few other game on my ps2 my tv screen just black and white but if i play other games like gran turismo 4 original japan, and nfs underground 2 it has colours.
完成的
显示更多的2条评论
添加一条评论
4个答案
已选择的解决方案
Tara, depends on how you have your PS2 connected. If you are using the component cables, check in the system settings and check if its in regular RGB. If you use the regular Yellow, Red and White cables, it should be in RGB mode.
这个答案有帮助吗?
得分 3
8条评论:
this didnt help me but my PS2 is in RGB mode already
完成的
Is ur ps2 modded
完成的
Now it won't let me view system settings it will only play movies n is still in black and white now I can't change it back from RGB that what's it normally was
完成的
i needed to change my tv to the AV channel instead of the component channel also to fully fix this issue
完成的
Thank you halo117ish
完成的
显示更多的3条评论
添加一条评论
最有帮助的答案
I was having the same problem but I changed my input from component to AV and that worked.
这个答案有帮助吗?
得分 12
14条评论:
I did exactly what you said and it works! Tq tq tq
完成的
Me too!!! Thanks a bunch! Putting on AV worked :D
完成的
Thanks a bunch, it worked!
完成的
How can i change my input to av ?
完成的
Just go to input it should be right on your remote for the TV and then you should see AV as one of the options then push the up or down arrow to go to the AV option the once you are on it the push select that's the button that says select on it yeah you just push that button.Thats it.
完成的
显示更多的9条评论
添加一条评论
This one is problem on the HDTV with tons of features in it. First go to your TV's settings and open option (in my case I'm using 50" Sharp Aquos 1080p), if you don't find it check something similar to above. Then, you want to change the "Input Select" from "Component" to "Video." This will change the color system automatically as "Component" label are for newer devices and sometimes can't cope with older devices such as PS2. After you've done it you might see the "Colour System" option and that's where colour calibration option exist. My TV sets itself to NTSC 3.58 where as the component shows 480i(with monochrome color).
这个答案有帮助吗?
得分 3
3条评论:
Thank you this helped a lot
完成的
That was exactly what fixed my issue.
thank you!!
完成的
Omg thanks so much
完成的
添加一条评论
My tv is LG and it’s showing black and white for my PS2
这个答案有帮助吗?
得分 0
2条评论:
@faousyjami27127 have you followed any steps in the given answers?What have you tried?
完成的
I had the same issue. You need to use a different input on your tv.
• Check the system settings: Make sure your PS2 is in RGB mode
• Check the cables: If you're using the yellow, red, and white cables, make sure they are in RGB mode
• Check the composite cables: Make sure they are not plugged into the component input
• Check the TV inputs: Different inputs will provide different levels of image quality
• Check the HDTV's operations manual:
Look for a game mode setting or instructions to turn off digital picture enhancements
• Adjust the contrast or sharpness settings:
This may help reduce jaggies
完成的
添加一条评论
添加你的答案
Tara 将永远感激不已
浏览统计数据:
过去 24 小时: 32
过去 7 天: 182
过去 30 天: 1,013
总计 260,309
