跳转到主内容
加入维修社区 - 创建账户
6.1 megapixels, ISO 200-1600, DX format, 1.5x field of view crop
Gaining access to flash components only
My flash quit working to I removed the top cover and noticed a contact that needed to be pushed in order for the flash to work, so I tested it by pressing the switch and the flash worked. Then I realized that there was a little grey bushing that was out of place enough so that it could not push the switch when opened. in the process of snapping that back into place a wire broke rendering the work to fix the flash worthless. I have read the instructions on how to take apart the D70 but it did not even mention the flash housing (possibly just the top)
So I was wondering is there a way to remove the top so I can repair the wire that was snagged without going through all the steps of tearing down the whole camera?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
michael, take a look on here and see if that will help you out.
这个答案有帮助吗?
得分 0
1条评论:
Thank you oldturkey03 that is what happened to mine I also used a paper clip to pull the bushing cam switch into place but was not careful enough breaking two wires. and I need to figure out how to fix the wires but they are inside where that grey bushing is
完成的
添加一条评论
添加你的答案
michael 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 6
总计 517
