How can I delete all personal information before selling my Pocket PC?
How can I remove all personal information from my Pocket PC and still leave the OS intact? It runs Vista, and has no drive, and did not come with a CD.
Like most Laptops nowadays, there could be a 'hidden' partition on the harddisk for recovery.
Toshibas use a special key combination to restore the original state.
Havde a look in 'help'- see if there is a restore option
这个答案有帮助吗?
did find a restore
great job!
+ Ralph
I know this is not the answer you're looking for, but there is no way to be 100% sure you're erasing all the data unless you wipe the drive and install the OS from scratch. There are 3rd party tools which claim to do this, but there are so many places that data can reside, and so many various registry keys that contain information, that it is very hard to guarantee everything has been deleted. And if you do delete the data to what seems like a satisfactory level, make sure to defragment the drive as completely as possible, because undelete/unerase utilities can very easily sniff out "deleted" data on a drive, and let the new owner have a field day with your data. Obviously, this is another reason to format the drive and start over -- doing so writes to the drive a sufficient amount that it would be very difficult for someone to resurrect what was on it.
It may be worth investing in a good external optical drive. If you deal with a lot of laptops, it's something you'll probably find a use for many times. Also, the laptop's manufacturer will likely sell you restore media for $25 or so, or you might have luck purchasing it on eBay, etc.
这个答案有帮助吗?
well, may have to see if it allows me to create restore disks and then like you said put it on a disk - unless I can create it on an usb stick
cheers
I would normally suggest 1 of 2 things. Ether getting a new HDD and installing a fresh install of the OS (old drive gets physically shredded). The other is using a utility such as D'Bans Boot and Nuke, to rewrite every bit on the drive to Zero. Both are Military grade standards for destroying sensitive computer data
But that doesn't solve your problem, you can't reinstall, and you want the Original OS intact.
You can try Microsoft's SDelete Utility to delete sensitive files
For mac users you can try Permanent Eraser
It all depends on how sensitive your personal data is. If there is no critical data on your computer, like banking information, tax info, or information that would be considered confidential for your work The above utilities should work fine for you.
这个答案有帮助吗?
Click on the Windows button, in the search box type “Administrative Tools” & double click on Disk Management, This display you’re Disk Partitions.
If you want to remove all your personal details from the system you should reinstall your operating system & format your hard drive. If you are selling your laptop it is best to format your hard drive a few times to make sure your details can’t be recovered by specialist software.
2nd year CompTIA A+ student &
City & Guilds IT Practitioner
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 7,527
