跳转到主内容
型号 A1213或A1218,闪存容量:8、16及32GB
disabled iPod(connect to itunes) says it needs to be unlocked
My iPod touch 1st generation says it needs to be connected to itunes. However, whenever I connect it, it says it's locked with a passcode.. I can't enter a passcode because it's saying to connect.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 160
10条评论
My iPod touch 4st generation says it needs to be connected to itunes. However, whenever I connect it, it says it's locked with a passcode.. I can't enter a passcode because it's saying to connect.
完成的
my ipod is disabeld and says connect to i tunes plzzz solve my problem
完成的
My ipod touch 5 says connect to itunes then says ,when i do connect it, it's locked with a passcode. How do I bypass the password and be able to change it and still have my app data and settings?
完成的
my ipod touch 4th gen says ipod is disabled connect to itunes and when i got on to itunes it said cant access ipod because its locked and i can remember my passcode now so please can you get back to me on this as soon as possible
完成的
my ipod is disabled and says connect to itunes pliz help me solve this problem
完成的
显示更多的5条评论
添加一条评论
5个答案
已选择的解决方案
Joy, "you can restore the device on the the same computer that you normally use to sync your ipod. Put the device into DFU mode, then open iTunes. Select your iPod in the sidebar, and click restore. This will restore the device to factory setting but it will DELETE ALL YOUR DATA if you have not backed it up, it will be lost. You put your iPod in DFU by
Turn off iPod
Hold power button for 3 sec
Hold power and home button for 10 sec
Continue to hold home button until iTunes pops up a message telling you that it has detected an iPhone in recovery mode. The screen should remain black
The only other way that I know of that you might try first is to erase the password but I am not sure if this would work when you are already disabled. This will not erase any data on your device. I guess you can always try and hope you have a windows computer :-) anyhow you plug in your iPod. Open My Computer (or Computer for Vista). Click on Folder options and enable to view hidden files. Next go to iPod_control and click on the folder named Device. If your iPod is locked, there will be a file _locked . Rename the file to _unlocked. Remove your iPod and it will be cleared" you can also check on here My iPod is frozen says I pod disabled?... Hope this helps, good Luck.
这个答案有帮助吗?
得分 28
14条评论:
Thank you so much it worked
完成的
Thank-you it worked.This was the best advise ever. Thank-you. I will make sure anyone that has this problem. I will tell them about your advise. Thank-you....
完成的
so today my friends were trying to get in my iPod 5 and says iPod is disable connect to iTunes would that work ?
完成的
Hi! I put my ipod on DFU Mode and I am holding the home button... There is no itunes message popping up???
完成的
I keep trying this but my iPod just keeps coming back to were I started and no iTunes message is poping up. am I doing something wrong????
完成的
显示更多的9条评论
添加一条评论
my ipod is disabled connect itunes
这个答案有帮助吗?
得分 5
1条评论:
How long to restore software?
完成的
添加一条评论
Well I know how to
1.turn off your I pod
2.hold the, lock bitten and the home in tell apple a apple logo pops up
3.let go of lock butten and keep home butten held
4 it will have a iTunes logo and a USB
5.cennet to iTunes
6.wait tell it loads up
7. Oyur, I pod is fixed
8.yay
这个答案有帮助吗?
得分 4
6条评论:
how do i do that when the power button is jamed
完成的
what do you do if you dont have itunes
完成的
dose this work for ipod 5gen
完成的
What if you can't get into your iPod 5 and can't do anything
完成的
works forr all ipods
完成的
显示更多的1条评论
添加一条评论
how long does the download last in minutes
这个答案有帮助吗?
得分 2
添加一条评论
Looks like it might be time for a wipe. :( try putting the iPod into DFU mode and restore.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Joy 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 57
总计 89,005
