跳转到主内容
The Panasonic Lumix DMC-TZ5 was released March, 2008. It is the third camera in the TZ series, with a 3.0 inch viewing screen, 28-280 lens (10x optical zoom) and 9.1 megapixels. The TZ5 also has 720p HD video recording.
22 个问题 查看全部
问题已关闭
The camera will not focus anymore
Right when you turn the camera on it says to turn of and on again OR it will say that it cannot focus. Won't even try taking a picture.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Lindsey, sounds like a bad lens. You can try and disassemble your camera and clean all the connectors. Also, clean the camera lens with some high grade isopropyl alcohol. If that does not work, you might want to consider changing the lens.
这个答案有帮助吗?
得分 0
添加一条评论
I now have the exact same problem. Now won't retract and won't turn on. :-(
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 2,423
