跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2201 个问题 查看全部
iPhone 4s battery not charging and showing fully charged sign
my iphone 4s is not charging now.. it was charging properly but now the fully charged battery sign is appearing when i connect it to a usb charger to my macbook.. its percentage is 20% and still full battery charged sign is appearing and the iphone is not charging.. i have restored it 3 times but problem has not been solved please help!
ITS NOT CHARGING AND FULLY CHARGED BATTERY SIGN IS APPEARING at 20-30% percent battery!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
5个答案
最有帮助的答案
Hi. It seems you may have a faulty battery. You might want to purchase a Replacement iPhone 4S battery. You can follow our free step-by-step iPhone 4S Battery Replacement guide. Good luck.
iPhone 4S Battery图片
产品
iPhone 4S Battery
$16.99
这个答案有帮助吗?
得分 2
添加一条评论
Same problem here, changing battery didn't help. Any suggestions?
这个答案有帮助吗?
得分 0
2条评论:
This question is almost one year old. you might get more of an answer if you ask your own question and give more details.
完成的
Replace the charging dock, should work, I've had a similar problem
完成的
添加一条评论
I purchased my iphone 4s via ebay and it charged fully. Then I installed the new apple update and the battery does not charge fully. It takes 12 hours or more just to reach 74% charged. What gives, do I need a new battery or what?
这个答案有帮助吗?
得分 0
添加一条评论
my iphone 4s not charging but showing full charge why that problem this is bettery problem or softwre problem please help me what to do?
这个答案有帮助吗?
得分 0
添加一条评论
on the iphone 4S, when changing the battery and dock don't help, more often than not the issue is damage to the components next to the battery connector. You can often confirm this as you will see temp sensor and gas gauge errors in the system log with a program like ibackupbot.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
aasdeepcheema 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 9,427
