跳转到主内容
大量松下数码相机的维修指南。
348 个问题 查看全部
PC does not recognize my camera, please help
I took a picture while my Panasonic Lumix DMC-ZS10 was connecting to PC and now it will not connect to my PC. I've tried taking the battery out, restarted the computer, turned off/on camera. Nothing works.
This error flashes when I try to connect "Picture is displayed for 4:3 TV for 16:9
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
It is really not an error that flashes. That is the output setting that is detected whenever the A/V cable is detected. I would start by resetting the camera to the default settings. Go to your setup menu and use the reset functions. You can also try to set it to USB first and see what happens. If you do not have the manual, download it from here.Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Polly 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 11
总计 2,559
