跳转到主内容
Why won't my iPod Nano 4th gen charge?
ipod wont charge just said to connect to power plz help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
How old is it? It sounds like your battery may need replacing.
完成的
well, IS your charger working?
完成的
添加一条评论
7个答案
最有帮助的答案
troubleshooting basics:
does your 'charging solution' work with another iPod?
have you tried someones working charger / cable / computer with your iPod?
这个答案有帮助吗?
得分 1
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
Also, sometimes connecting to a wall charger instead of a USB cable will fix the problem.
这个答案有帮助吗?
得分 0
1条评论:
edit-OR a car charger. those deliver much more voltage, sometimes it helps.
完成的
添加一条评论
Were it me, I'd probably try connecting it to the computer with the Apple-supplied USB cable. With this method, you are able to eliminate the variables of a bad wall charger and a bad USB cable. However, if it still doesn't charge even on Apple's cable, I'd take a look at the cable itself- I've had two or three get frayed open near the connectors, preventing the iPod from either charging or syncing- sometimes, both.
If the cable seems fine, you may be looking at either:
1)Dead battery, as others have suggested
2)Problematic docking connector.
To lessen the possibility of the second, I'd try jiggling the cable near the docking port. Sometimes, the connectors inside can be moved from their place ever so slightly- all it takes is two out of whack pins to prevent charging.
Of course, if it's still under warranty, there's always the option of taking it to Apple...
这个答案有帮助吗?
得分 0
添加一条评论
Re: Wall chargers.
Older Wall chargers use the Firewire voltage (something like 9-18VDC)charge port that was discontinued on 4th gen and higher Nanos .
Even though none of the Nanos use Firewire, generations 1 thru 3 can still be charged this way.
All chargers for the 4th gen, wall, car or PC USB use the same voltage of 5VDC, hence they make no difference on this model of Nano.
这个答案有帮助吗?
得分 0
添加一条评论
None this items work.
这个答案有帮助吗?
得分 0
1条评论:
mark, the best you can do is to ask your own question. Click on the link "ask a question" and give as much information as possible. Like, what happened, what device you have, and what you did so far to repair it. This question here is old and nobody will see that you need help with your device. Good luck.
完成的
添加一条评论
添加你的答案
jdog 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 4
总计 5,728
