跳转到主内容
这是一系列帮助修理洗衣机的指南和支持。
Why won't my washer agitate?
My GE 15 cycle HD Super Capacity Plus Washer won't agitate during the wash cycle but it does spin during the spin cycle. The agitator itself spins freely when the washer is not being used and I know that it did not do this before this issue started. They want almost $100 just to have a service tech come out to diagnose the issue. I need to be able to fix this myself, but don't know where to start as the back of the washer can not be removed. Please help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
mary vasquez, do you have any other number on your washer? A model number would be great:) From the symptoms you describe, it is possibly a transmission, agitator shaft issue. I'd like to gt a closer look at your particular model to help out a bit more specific.
完成的
添加一条评论
2个答案
已选择的解决方案
The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
这个答案有帮助吗?
得分 3
添加一条评论
Does the whole agitator need to be replaced
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mary vasquez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 1,913
