跳转到主内容
主板和 CPU 维修指南。
Another name for a motherboard?
Is there another name for a motherboard?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 10
7条评论
How does that increase the lifetime of devices?
完成的
I think this is a valid question because a common nomenclature is a critical underpinning of communication repair information. This is a common beginner question-- motherboard is actually a more commonly used phrase, but the Mac industry calls it a logic board.
完成的
They are called "mainboards".
完成的
They are also called MOBO for short.
完成的
I call mine Maxine.
完成的
显示更多的2条评论
添加一条评论
12个答案
已选择的解决方案
Logic Board is most commonly used around here.
这个答案有帮助吗?
得分 12
2条评论:
Additionally, motherboard is usually written without the space (i.e. not mother board).
完成的
Other names of MOTHERBOARD are 1. Main Printed Circuit Board; 2. Printed Wired Board (PWB); 3. System Board; 4. Main Board, abreviated or shortened to MoBo.
完成的
添加一条评论
as others have already said Logic Board is the other commonly used term. I've heard Apple refer to it as the MLB or Main Logic Board, too.
the term motherboard originates from early days of computers where the main circuit board contained the CPU and other major "logic" or chips, and usually also expansion slots. You could plug "daughterboards" into those slots to expand the functionality of the computer - e.g. printer interface, sound card, graphics card etc. That was a distinguishing feature of a motherboard.
p.s. to get into even more background of the terminology, the "board" part of this comes from the general term Printed Circuit Board, or PCB. this is the physical, non-conductive board on which there are conductive traces connecting the various electronic components. Logic board is just another way of referring to the PCB containing the major "logic" or chips of the computer.
这个答案有帮助吗?
得分 11
2条评论:
excellent +
完成的
And then you have the grandma board, uncle board, and nephew boards.
完成的
添加一条评论
Motherboard when we used cards stuck in it, logic board, main board
这个答案有帮助吗?
得分 5
添加一条评论
Sometimes the motherboard is also called the mainboard. That's a pretty old term, but I've seen it pop back up in technical literature from time to time.
这个答案有帮助吗?
得分 4
添加一条评论
Mobo is an appropriate slang term. Smartly saves specious speech syllables.
这个答案有帮助吗?
得分 3
1条评论:
Capital (MOBO)
完成的
添加一条评论
I have been an electrical engineering technician for 25 years and have called them "System Boards".
这个答案有帮助吗?
得分 3
添加一条评论
Logic Board
N.
这个答案有帮助吗?
得分 2
添加一条评论
The previous two are correct- Logic Board was mainly used as a term for MBs in earlier macs, however the term has stuck.
这个答案有帮助吗?
得分 2
添加一条评论
Dell calls them System Boards as well...
-- N
这个答案有帮助吗?
得分 2
添加一条评论
Mother of Daughter-s Boards
这个答案有帮助吗?
得分 2
添加一条评论
Motherboard is the main printed circuit board (PCB) found in computers and other expandable systems. It holds and allows communication between many of the crucial electronic components of a system, such as the central processing unit (CPU) and memory, and provides connectors for other peripherals.
这个答案有帮助吗?
得分 1
添加一条评论
The A+ exam used to call them Planar boards, and IBM/Lenovo uses that term.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
lucylu 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 63
总计 28,412
