跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2175 个问题 查看全部
Why does my iPhone 4s screen show black and blue lines?
My iPhone screen shows only black and blue vertical lines. The screen is not cracked, and still responds to my touch. I've already tried restoring it on iTunes, and I did a hard reset (holding the home and lock button until it turns off and back on).
What parts of the phone do I need to replace to get the display working again?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 31
3条评论
vicky how much will it coast
完成的
lauren norledge, sorry looks like Vicky hasn't been here since Aug 21,2012. The assembly will cost you anywhere between $35 and $100 depending on where you purchase it from.
完成的
that still didnt work for me George.... and i need this fixed or my mom will kill me. not literally but yea
完成的
添加一条评论
6个答案
已选择的解决方案
Vicky, your front display consist of multiple pieces. In your case the digitizer (glass) is still intact, but your LCD is no longer working. I suggest that you change the display assembly. Here is the guide for it. The assembly is available right here as well as many other places. Hope this helps, good luck.
iPhone 4S Screen图片
产品
iPhone 4S Screen
$34.99
这个答案有帮助吗?
得分 6
1条评论:
Thank you, I'll replace it as soon as possible :)
完成的
添加一条评论
Try pressing the home and power button at the same time but holding it down until it shows the apple sign. If that doesn't work you can rest your iPhone before sending it back for a replacement.
1- Hold down the home and sleep/wake button at the same time (In order to power off that way)
2- Once you were able to power off, next hold down on the home button and at the same time plug the USB cable into the phone and computer. Keep holding the home button until a message factory settings. It will take a few minutes for it to appear.
3- Once it does click on restore.
这个答案有帮助吗?
得分 0
添加一条评论
mine has done the same thing. im really worried that it might not work anymore. ive already cried today about it. what should i do ~ Aiyana Irving
这个答案有帮助吗?
得分 0
添加一条评论
i need help to and it does not work
这个答案有帮助吗?
得分 0
添加一条评论
Dropped my iPhone today and the screen didn't break, but blue and balck vertical lines show up when i press buttons. I have a lot of important text messages and pictures that i don't want to lose. My phone is still responsive but continues to only show blue and black lines on screen. Very worried and need help!!
这个答案有帮助吗?
得分 0
1条评论:
plz i have the same issue. how you fixed it ?
完成的
添加一条评论
You should follow the screen repair guide to replace the screen.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Vicky 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 197,694
