跳转到主内容
加入维修社区 - 创建账户
PowerBook G4 Aluminum laptops with 12-inch displays. Released in 2003 from Apple.
What could be broken?
Hello,
I need to have a diagnostic advice about my PowerBook 12" G4 1GHz that doesn't turn on anymore or better it goes on without screen, without harddisk noise startup. The only signs that make me think that is on are the light on the keyboard when I click on the Shift key or when I click on F5. Then to turn off I have to put out the power plug and the battery. When I put the plug in again with the battery the light on the plug changes from green light to orange for a while, then green again. The led on the knob to open the PowerBook doesn't light on. It gives only a light noise (zzzzz) when I turn on the computer. Which part do you think it is broken? If it is the DC-DC card it is more different than the motherboard!
UPDATE
I tried PMU and RAM out (as suggested): all remains the same. Tried to use 2 method with CD (also suggested): nothing. Before ordering DC-DC card, to be sure that isn't the motherboard could I do something more? Thanks to all!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
There's no other way to troubleshoot the machine you've got to replace parts. The DC in board is the first part to replace then you'll know if you need a logic board swap.
完成的
pram?
完成的
添加一条评论
4个答案
已选择的解决方案
Try a PMU reset first then take off the ram module from the ram slot and try to boot the machine. If nothing works then yes the DC in board could be faulty. Make sure your AC adapter is fully functional. Be aware that the problem could also be related to the logic board.
这个答案有帮助吗?
得分 1
添加一条评论
Your power appears to be fine. Try starting up from your installation disk. Insert the disk part way, hit the start button and push the CD all the way in. Immediately hold down the "C" key and see if it will boot. Next do the same thing with an external monitor plugged in.
这个答案有帮助吗?
得分 1
添加一条评论
My 12" PB got dropped from about 5 feet by a porter and then failed to come on. When I pushed the 'on' button, I'd hear a couple of clicks, feel the HD spin up but nothing else. No screen, non-responsive to keys and had to not only unplug it, had to remove the battery to turn off. The top of the unit where the HD sits got EXTREMELY hot. Was told by a 'repair' shop that the motherboard was damaged and it would be cheaper to get a newer machine than repair the PB. That was 15 months ago. A couple of weeks ago I salvaged parts (memory and optical) to upgrade an iBook and put the old parts back in the PB for practice/experience. I thought what the heck, wonder if it now works?? And it did!! Must have been a connection that got knocked loose. Not saying if your situation is the same but the optical removal was nearly a complete teardown so most if not all the connections were 'broken' and then remade. Couldn't hurt to try on yours. If it does not work, what have you got to lose other than time. Think of the experience you will gain. The instructions provide here are excellent, and easy to follow. Just read them a couple times before starting work (I know, we don't need no stinkin' instructions. wrong). It will make the work easier plus you will catch some facts (like the need for thermal paste for when the heat sink gets re-installed). Just my nickel input.
这个答案有帮助吗?
得分 1
添加一条评论
Try pushing the button on the bottom of your batter and see if any of the lights come on the battery.....if they do then you have some life in your battery and odds are the problem is your logic board.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Francesco 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 18
总计 1,092
