跳转到主内容
iGrill 无法开机
更换电池
检查电池电量是否充足。如果电池无法正常工作,你需要更换电池。
检查电池方向
如果电池电量充足,请检查电池在设备中的安装方向是否正确。
软件或硬件可能发生故障
目前没有针对该问题的常规解决方案。
屏幕上数字闪烁
探头 1 或 2 未连接到设备
设备无法识别其中一个或两个探头。如果金属接点未与探头接触,你可能需要进行修复。
屏幕上闪烁除 1 和 2 以外的数字
电池电量可能不足,或遇到软件问题。尝试更换电池以纠正此问题,否则该问题可能无法通过常规手段解决。
iGrill 闪烁 8.8.8 或 LED 灯持续闪烁
电池电量过低
电池无法正常工作或电量不足。请更换全部 4 节旧 AA 电池并重试。
无法连接蓝牙
重置蓝牙设置
如果连接的设备无法发现 iGrill,或者屏幕上没有显示蓝色蓝牙图标,你必须重置蓝牙配置。按住“加号”和“减号”按钮,按下电源按钮,然后重复此操作。接着按住所有三个按钮,直到听到长而稳定的蜂鸣声,听到蜂鸣声后松开按钮。
你的设备可能存在问题
尝试将你想要连接 iGrill 的设备连接到其他设备上。连接问题可能出在发起配对的设备上。
iGrill 没有声音
检查音频组件
确保内部音频部件焊接良好。
Kyle McElyea
于02/16/16注册
259 声望
创作了2篇指南
团队
IUPUI, Team 3-4, Harley Spring 2016 IUPUI, Team 3-4, Harley Spring 2016 的会员
IUPUI-HARLEY-S16S3G4
4 名成员
创作了48篇指南
14条评论
IGrill2 paired with my iPad but won't show up on my iPhone. Both have the Weber App. I initially paired with iPad and installed new firmware. When trying to pair with Iphone, the pairing icon flashes for about a second in the upper right of the app, then goes away. In Bluetooth settings, it shows up on my ipad but not on iPhone. I also have the mini, which shows up on both devices no problem. What do I need to do?
Steve - 回复 分享
They can only pair with one device at a time.
Greg Millar - 回复 分享
I've always had trouble getting mine to pair reliably. Here is is, Thanksgiving, and it refuses to pair.
fiedlerh - 回复 分享
So what does
"Software or Hardware Problem
Acurrent solution to this problem [not turning on] is not available by normal measures" mean, exactly?
My iGrill does. It turn on. Batteries are good and are correctly oriented. What are the abnormal means I can try?
This is very frustrating...
andreraiche - 回复 分享
i think its just a bit temperamental, mine constantly said bluetooth stopped working, i just kept trying to turn off the app and turn it on again - I could see that my phone (android) was pairing in the device settings, so i unpaired it to see if the app would pair it - eventually after about 10 times turning on and off various things it worked. frustrating. also why does the app have a sales pitch for a device i already have? just makes the app more confusing and less intuitive.
Mathew Williams - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 56
总计 43,606
