跳转到主内容
学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
听不到游戏语音聊天
耳机无法听到群组聊天声音。
未连接到手柄
确保耳机适配器已完全插入 Xbox One 手柄。
聊天音量过低
在 Turtle Beach 手柄适配器上,通过按下适配器聊天侧的向上箭头增加聊天音量。
麦克风无法工作
对着麦克风说话时,系统无法识别你的声音。
未完全插入
确保麦克风连接器已完全固定在耳机上的插孔中。如果未推到底,请进一步推入。
手柄更新
如果你的 Xbox One 手柄固件未运行在当前版本,它可能无法与耳机适配器配合使用。更新至最新版的手柄固件可能有助于麦克风正常工作。
适配器无法插入手柄
无论怎么尝试,你都无法将耳机适配器装入你的 Xbox One 手柄。
针脚不对齐
遗憾的是,有些耳机适配器在出厂时就存在针脚不对齐的问题,因此无论你如何用力,它们都无法装入 Xbox One 手柄。如果遇到这种情况,请联系购买耳机的零售商或 Turtle Beach 以寻求更换。
声音和/或麦克风断断续续
声音时有时无。耳机可能只有在电线以特定方式弯曲时才能正常工作。
电线受损
可能需要进行更换。但是,如果有人想尝试自行维修此问题,我们将提供易于理解的插图,说明电线类型、长度和焊接步骤。注意:尝试维修可能会导致保修失效。
游戏主机无法识别耳机
游戏主机未显示或识别出已连接耳机。
检查兼容性
该耳机兼容多种游戏主机。我们提供了兼容的游戏主机列表。如果问题持续存在,则可能是其他地方出现了问题。
Murilo S
于09/27/15注册
155 声望
撰写一个指南
团队
UMass Dartmouth, Team 3-1, Shastany Fall 2015 UMass Dartmouth, Team 3-1, Shastany Fall 2015 的会员
UMASSD-SHASTANY-F15S3G1
3 名成员
创作了36篇指南
11条评论
On my Xbox one dashboard is shows that there is no headset/mic connected to the controller, I've tried just about everything and there is still no audio going into the headset and I also can't talk to anyone in Xbox parties. Both my headset and my console is up to date with the latest version and I still have the same problem, my headset is brand new and the wires are fine, I'm thinking it may be a problem with either my adapter or my xbox one controller..... Can anyone relate to this issue? Or does anyone have any solutions? Oh, and I've done everything that Xbox support told me to do and it's still having the same issue.
Breanna Bowles - 回复 分享
The same thing is happening to me and I have tried using a different controller and it works fine , not sure weather it s a problem with my controller . Also the controller that it works on is the old version , not sure if that has anything to do with it or not .
Jack Rogers - 回复 分享
I'm having the same problem. Have you been able to figure out the issue?
ayedurand - 回复 分享
2 days ago when I was in a party chat with my friends my mic sounded perfectly fine but now they say it sounds like I'm mumbling or far away
Ted - 回复 分享
why is it not working anymore gives us answers
Jackson Ramos - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 27
总计 28,983
