学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
Toshiba Satellite C855D-S5303 Troubleshooting
Laptop Fails to Charge
You are unable to charge laptop when battery appears drained.
Broken Charging Cord
If laptop is not charging when plugged in, try plugging in to another outlet. If laptop still fails to charge, try plugging into another laptop of the same variety if available to you to determine if it is the charger or the computer at fault. If another identical device is not available to you, consider purchasing a new charger.
Faulty Battery
If the laptop fails to charge and the charger is not the reason for that issue, the battery may be the cause. See how to replace battery here.
Laptop is Overheating
Your Toshiba Satellite is shutting down due to being extremely hot.
Broken Internal Fan
If your laptop is overheating, check to see if any air is blowing out of the vent on the right back corner of the device. If no air is being vented, your internal fan may be broken. See how to replace fan here. (Will insert link upon completion)
Laptop Appears to be Running Slow
The overall performance of the device is of a lower quality than normal.
Computer Interior is Dirty or Dusty
If laptop is experiencing poor performance or lack of storage, a good first check is the cleanliness of the interior of the device. If it appears dirty or dusty inside, spray compressed air or wipe gently with a microfiber cleansing cloth, then check to see if performance is improved.
Faulty RAM
If the laptop is still not performing well after cleaning, the RAM may be faulty and require replacement or repair or the amount of RAM may be insufficient. See how to replace or add more RAM here. (Will insert link upon completion)
Laptop Appears to not be Saving Files
My Toshiba Satellite is not saving my files.
Try Replacing or Expanding your Hard Drive
If your laptop is not saving files, the hard drive may be full or faulty. If you can access your files, but cannot save anymore- expanding your hard drive by buying an external hard drive. If you cannot access your files or save them, your hard drive may be faulty and you'll need to replace it. Either way, you will need to access your current hard drive. Here's how.
Disc Drive is not Ejecting
"I put a CD in and I can't get it out."
Try Replacing your Disc Drive
If your disc drive is not ejecting, it may be broken and in need of replacement. Here's how (will link when complete).
3条评论
I can see my staring point
Raul - 回复
Where si located the amd vídeo controles chip?
Juan Lopez - 回复
I need to find the amd vídeo controler.
Juan Lopez - 回复
