跳转到主内容
Toshiba Satellite C855D-S5303 Battery Replacement
  1. Toshiba Satellite C855D-S5303 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Lay your laptop upside down on a flat surface.
    • Power off your laptop and unplug the charger.
    • Make sure you allow the laptop time to cool so that you aren't removing a hot battery.
  2. Toshiba Satellite C855D-S5303 Battery Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite C855D-S5303 Battery Replacement: 步骤 2 中的图像 2,2
    • Locate the right eject switch, labeled "1".
    • Slide the switch all the way to the right and it should stay in place.
  3. Toshiba Satellite C855D-S5303 Battery Replacement: 步骤 3 中的图像 1,1
    • The second eject switch is on the left and it is numbered "2".
    • Slide the switch to the left and remain pushing on it, because unlike switch "1" it will not stay in place on it's own.
  4. Toshiba Satellite C855D-S5303 Battery Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite C855D-S5303 Battery Replacement: 步骤 4 中的图像 2,2
    • With hand still pushing the left switch, grab onto notch at the center of the two switches.
    • Pull up and towards you. The battery will begin to lift out of the device.
  5. Toshiba Satellite C855D-S5303 Battery Replacement: 步骤 5 中的图像 1,1
    • The battery can now be pulled out entirely. You are ready to replace it.
结论
2等其他人完成本指南。
Courtney Burns
于10/20/16注册
836 声望
创作了5篇指南
团队
UMass Dartmouth, Team 2-5, Isaacson Fall 2016 UMass Dartmouth, Team 2-5, Isaacson Fall 2016 的会员
UMASSD-ISAACSON-F16S2G5
3 名成员
创作了10篇指南
一条评论
It appears likely that these batteries are NICAD type. And NiCad batteries CAN be reprogrammed to accept charge.
Is that possible with these Toshiba units?
Rick Walker - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 1,003
