跳转到主内容
学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
TI-30 XS 无法开机
无论你怎么做,计算器都无法开机。
屏幕对比度过低或已关闭
如果计算器看起来没反应,可能有一个简单的解决方法。在拆开设备前,请先检查对比度设置。对比度可能被设为零或非常低,这会让人误以为电池没电了。
电池没电
如果 TI-30 XS 在户外直射阳光下无法开机,那么电池很可能已经没电了。遗憾的是,TI-30 XS 无法充电,因此需要更换电池。
显示面板损坏
如果你已经排除了其他可能性,而计算器仍然无法开机,那么可能是显示面板损坏了。你需要更换一块新的显示屏。
屏幕亮起后随即熄灭
计算器开机后不久,屏幕就会熄灭。
布线故障
如果屏幕闪烁后熄灭,说明它仍在通电,但供电不足。这个问题可能是由布线故障引起的。如果是布线故障,则需要重新连接并重新焊接从屏幕到电池的排线连接。拆下计算器的后盖后即可接触到该连接处。
电池没电
如果屏幕亮起后立即熄灭,可能是电池电量过低。如果是这种情况,则需要更换电池。
电池续航时间极短
即使装入新电池,计算器的电量似乎也比平时消耗得更快。
太阳能电池板失效
如果你更换了电池但电量依然消耗很快,那么用于为电池充电的太阳能电池板很可能已经失效。请检查顶部前面板是否被遮挡,确保光线可以进入。如果太阳能电池板没有被遮挡,则需要更换。
按钮卡滞
按钮无法快速回弹,或者完全无法回弹。
键盘内有污垢
按钮无法回弹很可能是因为有污垢或其他异物阻碍了按钮的活动空间。尝试用压缩空气吹扫键盘,清理该区域。
Nancy Ruiz
于09/22/15注册
351 声望
撰写一个指南
团队
Cal Poly, Team 11-2, Forte Fall 2015 Cal Poly, Team 11-2, Forte Fall 2015 的会员
CPSU-FORTE-F15S11G2
4 名成员
创作了36篇指南
15条评论
This calculator has been decent over a short period of time. However with minimal dropping and caressing of the fist, knee, and elbow it stopped operation. I am quite disappointed in this product and its overall performance in a highly competitive math environment. The versatility of this calculator is poor, it is not well suited for many landscapes. I tried to do my math in the pool like I always do with my previous Casio brand calculators and to my disappointment the TI-30X IIS, failed to preform in a similar way. In another case I was watching the film, 12 Years A Slave, and I was attempting to calculate the real world current GDP value of slavery in the present day. This was even more of a complete and utter disappointment than the pool incident. I hope that you will improve this product in all aspects and begin to actually care about the people you are presenting these terrible products to.
ALEC SIMMONS - 回复 分享
This is a joke right?
Arne Cl - 回复 分享
The calculator froze. What do?
Pika Girl - 回复 分享
Mine just did the same. Did you ever find a solution?
millieiei - 回复 分享
In my class, my TI 30X IIS always answers with 69 no matter the equation inputted. Also sometimes it will just add a 5 to the end of the answer. Why does this keep happening and how do I fix it?
Flamingo Man - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 41
过去 30 天: 186
总计 44,498
