跳转到主内容
学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
飞行时晃动
飞机刚起飞就开始晃动,并且情况逐渐恶化,直到坠毁。
陀螺仪损坏
陀螺仪很可能是在坠落或顶部转子撞击物体时损坏的。请参考 Syma S107 陀螺仪更换指南 来解决此问题。
悬停时旋转
悬停时表现良好,且你已经在遥控器上调节到了极限,但它仍然会在不触碰遥控器的情况下向左或向右旋转。
转子电机故障
其中一个主转子电机动力不足或即将损坏,导致两个主转子以不同的速度旋转。请参阅 Syma S107 转子电机更换指南以更换电机。
无法开机
你已经为 S107 充电,但打开开关后没有任何指示灯闪烁。
电池故障
电池可能因为频繁的快速充放电而电池没电。此外,电池线可能已经断裂或与电路板断开连接。请按照 Syma S107 电池更换指南安装新电池或重新连接电线。
电路板故障
电路板可能发生短路或出厂时就存在缺陷。请参考 Syma S107 电路板更换指南安装一块新的电路板。
Christopher Smith
于10/11/14注册
305 声望
撰写一个指南
团队
USF Tampa, Team 1-31, Donnelly Fall 2014 USF Tampa, Team 1-31, Donnelly Fall 2014 的会员
USFT-DONNELLY-F14S1G31
1 名成员
创作了12篇指南
14条评论
I just bought a S107g. Right out of the box I turned it on and the light lite up. Added battery's to the controller and just tested it to see if it worked. The blades spun. Tried it again quick as to not take off. All looked good. Tried it a third time to get lift and had no response at all. Lights in the front are on and the led on the R5 board is on. Did a full charge from the controller. Still no response. Any ideas? Did the board short out?
Mike - 回复 分享
Ours worked well for exactly one day …. and then suddenly we had the same problem as you. The blades would spin but it just will not lift off, as if it no longer has enough power. Were you able to solve your problem and if so how?
Jim Albritton - 回复 分享
Flew this for a total of less than 5 minutes.  After one *VERY* soft crash on grass, the bottom set of blades stopped turning and the motor sounds like it’s working or clogged or something.  The gears inside that are connected to the bottom wings don't appear to be spinning at all.  Without the bottom wings active, the helicopter doesn’t generate enough lift and won’t go airborne.  Halp!
Arthur - 回复 分享
We are experiencing the very same thing! Soft crash landing and bottoms rotors won’t spin
Brittany Pigeon - 回复 分享
What do I do if it wobbles during takeoff and sometimes it just randomly stops and goes down low even though it’s fully charged will new parts help and tell what parts I need it also has a Brocken wing.
jcm.cool - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 20
过去 30 天: 105
总计 23,052
