跳转到主内容
学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
电源按钮无法响应
设备无法开启/关闭
电源故障
如果主屏幕按钮无法开启或关闭设备,可能是因为电池没电。若要更换电池,请参照此处的电池更换步骤 Sony SRS-XB30 电池更换。
设备随机关机
设备在没有手动操作的情况下持续关机
布线磨损或错位
内部布线有时会磨损或相互缠绕,导致设备突然断电。要解决此问题,你可能需要检查连接到电源的布线。如果需要,请尝试按照此处的指南 Sony SRS-XB30 布线更换 解开它们。
设备无法充电
问题可能是以下原因之一:
充电器故障
尝试更换另一个充电适配器。如果设备仍然无法充电,则需要购买新的适配器。你可以在线上或实体店购买新充电器。
充电口
如果设备更换适配器后仍无法充电,则需要更换充电口。更换步骤请参考此处 Sony SRS-XB30 充电口更换。
设备无法进行蓝牙配对
如果你的设备无法与其他蓝牙设备配对,问题可能是以下原因之一:
设备上的重置按钮
在进行任何机械拆卸之前,或许可以通过重置设备轻松解决问题。你可以按下重置按钮来完成此操作。重置按钮位于设备背面的翻盖下。按住此按钮十秒钟。
蓝牙芯片更换
如果你的设备仍然无法与其他蓝牙设备配对,则需要更换蓝牙芯片。指南 Sony SRS-XB30 蓝牙芯片更换 将为你提供更换蓝牙芯片的步骤。
设备播放声音失真
如果你的设备发出的音质失真或完全没有声音,以下建议或许有帮助:
其他信号干扰
确保通过蓝牙连接到扬声器的设备没有内置收音机或调谐器,因为这可能会干扰扬声器的音质。
扬声器更换
设备的扬声器可能需要更换。请按照此处指示的步骤 Sony SRS-XB30 扬声器更换 更换扬声器。
5条评论
I've tried to reset my speaker but it still won't turn on or charge
s.powell - 回复 分享
I have this speaker model, and the original charger that came in the box broke with the top of the pin still lodged in the charging port. The speaker worked till the previous charged battery lasted, however, after that, it did not charge with a new charger either. Any suggestions?
Tanmaya Purohit - 回复 分享
I've mistakenly changed with 18v charger so then it won't charge nor turn on. No response.. what should i do? T.T
alicoronnie - 回复 分享
I unplugged the unit from its charger (at the unit, not from the wall) while I was actively playing music through a bluetooth connection. The sound stopped immediately, which apparently is normal, but now I can only get sound from bluetooth if the unit is plugged in to power. No sound at all using the battery. I’ve tried resetting the unit, terminating and reconnecting the bluetooth device, using bluetooth standby - nothing works in regaining sound using just the battery. What is wrong with the unit?
Gib Mastri - 回复 分享
I have just fitted a new battery to the srsxb30 but still not working won't turn on , have tried reset , I have looked for a replacement charging box but am unable to find one have looked on Sony parts and on the Internet. Any help please
Philip Bracken - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 27
过去 30 天: 70
总计 20,065
