跳转到主内容
无画面 / 黑屏
确认游戏主机已开机,且游戏卡带已完全插入并固定到位。如果问题依旧,请使用压缩空气罐(气溶胶)或棉签清理游戏接口中的灰尘(指南:清理游戏接口)。
设备无法开机
确认交流电源适配器线缆已插好。检查交流电源适配器线缆是否有明显的撕裂或磨损。如果问题依然存在,请在拆开 Sega Genesis 后(指南:拆解设备),检查电源接口处的焊接连接是否脱开。如有必要,重新焊接。
画面雪花
Sega Genesis 未能与电视连接。
确认射频(RF)线缆已完全插入电视和主机,并检查线缆是否有损坏或故障。此外,在拆开 Sega Genesis 后(指南:拆解设备),检查射频(RF)接口处的焊接连接是否脱开。
手柄工作异常
可能是由手柄或手柄接口故障引起的。
确认手柄已完全插入主机接口。如果插好了,尝试在同一个接口换一个手柄测试。如果这个手柄能用,说明是第一个手柄有问题(点击此处购买新控制手柄)。如果换了新手柄还是不能用,那很可能是手柄接口有问题。
无声音
射频(RF)线缆存在问题(可能是连接问题或线缆故障)。
确认射频(RF)线缆已接好。尝试摇晃一下线缆;如果这样也不行,则需要更换线缆。(点击此处购买新射频线缆)
点击此处返回 Sega Genesis 设备页面
Erik Bjornstrom
于10/04/10注册
852 声望
创作了3篇指南
团队
Cal Poly, Team 3-29, Regan Fall 2010 Cal Poly, Team 3-29, Regan Fall 2010 的会员
CPSU-REGAN-F10S3G29
4 名成员
创作了60篇指南
24条评论
just got the system for free with the power cord. no games yet. but plugged it in to see if power light turns on and it doesnt light up. does a game have to be inserted in order for the power light to light up? dont wanna buy games if it doesnt work. thx.
pencejesse - 回复 分享
So my sega will turn on just fine boots any game is in perfect condition but the sound is just weird like it will have the regular sound but with a buzz like a static noise like the console is dirty or clogged I took it apart and cleaned making sure I got every thing and still makes that weird sound idk if it’s just the old ness of the console or my RF cable is bad or I need to clean better but reply if you know.
MaxsonTroubleshoots - 回复 分享
^^its the sega genesis atgames console.
pencejesse - 回复 分享
The atgames genesis is NOT a true genesis. It is a cheap plug-n-play games console. If you depress the power on the front you indeed will see a power light, so this one is broken.
You are better off getting a real genesis used as these units are notorious for sound issues.
Howard Casto - 回复 分享
I just picked up a high definition sega Genesis and a few games. Hooked it up the next day, popped zero tolerance in and it worked great. Played that for about half an hour, took it out and popped in a different game. Nothing.
John Latimer - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 27
过去 30 天: 165
总计 105,822
