跳转到主内容
蓝牙连接功能问题
设备已开启但无法连接
蓝牙已断开
在连接蓝牙之前,必须先将其与你的设备进行配对。确保两台设备的蓝牙均已开启。为此,请进入手机的“设置”,然后点击“蓝牙”选项。你将看到附近可发现的蓝牙设备。选择你的条形音箱设备名称,并点击“连接”。配对成功后,设备名称下方应显示“已连接”。除非你关闭任一设备的连接,否则设备将保持配对状态。
蓝牙传感器故障
尝试将条形音箱与其他设备的蓝牙进行连接。如果在尝试连接其他设备后仍无法连接蓝牙,请考虑按照此 指南 更换蓝牙传感器。
电源线故障
Polk MagniFi 条形音箱无法开启或无法保持开启状态。
电源适配器故障
确保电源适配器已插好,且充电指示灯亮起。如果适配器已插入但指示灯未亮,说明适配器有故障。如果你手头有电压相同的适配器,请用它测试条形音箱。如果测试可用,请尽量使用该适配器。
如果这无法解决问题,请按照此 指南 更换内部电源适配器。
条形音箱音量调节无响应
条形音箱已开启且有声音,但无法调节音量。
音量按钮失灵
如果遥控器可以正常工作,但条形音箱上的按钮没有响应,请尝试拆下按键并清洁按键下方,以清洁按键。按照此 指南 将按键装回原位,然后测试音量按钮。
条形音箱随机开关机
你已检查所有连接且确认应该能正常工作,但设备依然无法正常使用。
主板功能异常
Polk MagniFi 条形音箱已连接电源,但无法开启。
如果条形音箱无法开启,请检查电源线连接、交流电源适配器或电源按钮。对上述所有选项进行故障排除。如果它们都能正常工作,那么主板损坏的可能性很大。要修复此问题,请按照此 指南 更换主板。
功能故障
条形音箱已成功开启,但无法执行任何操作。
针对蓝牙连接和音量调节进行故障排除。如果所有功能均无法使用,那么主板损坏的可能性很大。点击上方链接更换主板。
电源按钮失灵
按照此维修 指南 拆下电源按钮。务必清洁按钮及其下方,以清除导致按钮卡住的残留物。
[deleted]
于10/22/18注册
695 声望
创作了4篇指南
66条评论
I switch TV on, Polk MagniFi Mini switches on automatically.- I swith Polk MagniFi off /by remote or by pressing the button on the Item/.- Polk stay off for a minute and switch on bu itself.It is not a problem of remote, but it is a problem of the device set up. It live its own life.- it stay off when TV is off.BTW - it is a POLK forum. Is there anybody from Polk support on it. I need straight answer to my problem not blah blah blah of what is intended to do. In my opinion it should be intended to do what Owner desires
yhds - 回复 分享
Polk Magnifi Max sound bar…
I would gladly replace the motherboard, at this point. The remote has a very narrow window where it can see the sound bar and command have to be pushed twice. The remote has been doing this out of the box. Every change of source material requires resetting the volume, voice and bass after it turns off henever you're distracted for longer than ~ five minutes it can't even remember where it was set. There's no way to save any settings at all. Please help! I am a technician and an audio engineer and I have a bench. Is poke ever going to accept the fact that their rushed control design just doesn't cut it? It's been a long time since I purchased this unit so where are my updates???
Frank DuVall - 回复 分享
After selecting Bluetooth via remote, my audio comes on for six seconds, mutes itself for three seconds and then the cycle repeats itself. How do I fix that? Although Opt 1 works, I prefer to connect via Bluetooth for better surround sound.
C. Monson - 回复 分享
Were you ever able to fix this? This is what mine is doing now! Driving me nuts
taillonamanda - 回复 分享
Magnifi One soundbar, everything seem to work but no sound. I tried all different inputs… still.
If mother board problem, where do I get it?
ekang56 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 34
过去 30 天: 122
总计 65,111
