跳转到主内容
学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
相机无法开机
相机已接通电源,但无法充电或无法保持电量。
电池没电
按住电源按钮以开启相机。如果此操作无效且相机无法开机,则电池可能未充电。要解决此问题,请将 USB 线连接到相机并插入墙壁插座。如果问题依旧,则电池可能已损坏。请考虑更换电池。请参阅 Nikon COOLPIX S3600 Battery Replacement.
电池损坏
按住电源按钮以开启相机。如果此操作无效且相机无法开机,则电池可能未充电,需要更换。请参阅 Nikon COOLPIX S3600 Battery Replacement,获取关于如何取出和更换电池的指南。
充电器损坏
充电口可能积灰或已损坏。尝试用嘴吹气或使用压缩空气罐清除灰尘。如果这样无效,问题可能出在 USB 线或充电适配器上。确保适配器已插好。然后尝试更换一个插座。如果问题依然存在,请尝试使用另一根 USB 线或一个新的充电适配器。
相机电池盖板损坏
电池仓的锁扣已损坏。
电池盖板损坏
如果你能看出电池盖板已损坏,这可能会影响相机的功能。损坏的盖板可能会让灰尘和杂物进入并损坏电池。如果问题依然存在,你可能需要更换电池盖板。请参阅 Nikon COOLPIX S3600 Battery Cover Replacement.
相机无法保存照片
相机可以拍照,但无法保存照片。
存储卡故障或损坏
相机拍摄了照片,但未能将其保存到存储卡中。请取出存储卡并重新插入,以确保安装到位。如果问题依然存在,则可能需要更换存储卡。请参阅 Nikon COOLPIX S3600 Memory Card Replacement Guide.
jriley
于03/16/15注册
116 声望
撰写一个指南
团队
Colorado Springs, Team 1-3, May Spring 2015 Colorado Springs, Team 1-3, May Spring 2015 的会员
UCCS-MAY-S15S1G3
6 名成员
创作了36篇指南
15条评论
This camera is junk. I just bought one, and it started acting up the very first day.
The battery is fully charged but the on/off switch of the camera seems to be unresponsive. If you take the battery out, and put it back in, suddenly the on/off switch will start to work. Once or twice. If you try to turn it on again, a few minutes later, it's unresponsive again. Sometimes, you need to remove and replace the battery, several times, before you "get lucky".
michblogs - 回复 分享
I have exactly the same issue.
gazstao - 回复 分享
The new firmware 1.1 should fix it
gazstao - 回复 分享
My Coolpix s3600 is not operating. When I turn it on a red light comes on in the front and the zoom comes out but the screen does not light up. It also would not shut down. I have to take out the battery and reinsert it and then the camera shuts down by itself. This started when I inserted a memory card. Now it is doing the same thing even when the memory card is not there. I first inserted a micro sd card with adapter and later I inserted a regular sd card. I have installed the latest driver from the website but still cannot get the camera to operate.
Tilak Banerjee - 回复 分享
I'm having the same problem, but the problem appears unrelated to the SD card. It will randomly sometimes function normally.
Brian Holt - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 19
过去 30 天: 75
总计 6,985
