跳转到主内容
放大器无法开机
“一切都已连接好,但毫无反应!”
电池安装不当
确保正负极与电池仓内的 + 和 - 标记对应。
电池没电
更换一块新的 9V 电池。
使用交流电源无法开机
连接可能松动。使用电压表测试电流。
放大器没有声音
“通电了,但吉他发不出任何声音!”
吉他连接不当
确保使用了正确的线缆,并连接到了放大器的“输入”插孔。
吉他功能异常
尝试在该放大器上使用另一把吉他,或者将这把吉他连接到另一个放大器上,以确定是哪个设备出了问题。
电路板上的元件损坏
电路板上有许多元件,如果损坏可能会导致没有声音。查看本指南了解更多详情。
耳机无法使用
“我插好了耳机,但耳机里没有声音”
耳机接触不良
确保你使用了正确的线缆或适配器。
电路板上的元件损坏
扬声器发出嘶嘶声
“这嘶嘶声吵得我没法演奏了!”
扬声器故障
查看本指南以更换扬声器。
电路板上的元件损坏
电路板上有许多元件,如果损坏可能会导致发出嘶嘶声。查看本指南了解更多详情。
旋钮无效
“转动旋钮但声音没有任何变化。”
电位器损坏
查看本指南以测试和更换电位器。
电路板上的元件损坏
电路板上有许多元件,如果损坏可能会导致电位器工作异常。查看本指南了解更多详情。
David
于10/29/13注册
38 声望
创作了0篇指南
10条评论
Hi everybody,
I have a problem with my MS-2. It turns on but produces no sound. I took it apart but visually all components and connections seem fine. I haven't tested them, and I'm not sure what I should test. I see that there is a link to a guide, on this page, but the link doesn't work. Did anyone experience the same problem ?
Thank you for your help !
ziuthre - 回复 分享
Hi Ziuthre, i have the same problem with mine, the led turns on to, but makes no sound at all. some time, a friend, conect it a 12V adapter on it, and.... so, if you have any information about it, please let me know at teratossiete@hotmail.com... same if i know something... thx
Luis Aguirre - 回复 分享
Links are explicitely leading to an error404 page. I mean the page isn't missing, the link is built to show up this 404 page, so I think the guide's never been written :(
"http://www.ifixit.com/404"
agapoffa - 回复 分享
The tone knob on my Ms-2 is stuck, I can't move it. What do I have to do?
Sander Lijster - 回复 分享
Gently prise off tone knob with small flat end screw driver. Working your way round till it pops off.
Remove 10mm lock nut with socket. Should only be finger tight so should come off easily. With the amp lying on its back squirt a very small amount of penetrating oil into the shaft / switch. Gently and carefully push the shaft / switch to the side so that oil can work it’s way around. Leave for a minute or two.
Now with a flat ended screw driver (about 7”long for leverage) carefully but firmly try to turn the switch. Should come free at this point.
Mine was stuck for over 10years and it freed up easily. Wipe away any excess oil and reassemble.
Ken - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 32
过去 30 天: 109
总计 12,459
