跳转到主内容
学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
键盘灯不亮
我的键盘灯不亮。
如果键盘灯设置不当,灯光可能会保持关闭状态。首先,检查设置并确保灯光选项已开启。如果已开启,你需要重新将线缆连接到电脑。此外,你也可以用另一台电脑测试该键盘。
按键无法按下
键盘按键卡住了。
由于泼洒了饮料,按键可能会卡住无法按下。你可以尝试将其重新装回键盘,并确保下方没有异物卡住。然后,尝试轻轻按下直到听到咔哒声。请确保按键安装方向正确,以免损坏按键电路板。
背景颜色无法显示
无法显示颜色。
所谓的“故障”背景颜色是指你在使用键盘时,中框处没有颜色,或者显示的颜色不是你预设的颜色。这是由板载闪存造成的,大多数情况下是因为缺少颜色设置。因此,当你注销时,你正在使用的颜色会被卡住而无法加载。有两种常见的故障排除方法。一种是激活灯光,另一种是在 Logitech G910 软件中自定义灯光设置。
打开 Logitech Gaming Software 并点击灯泡图标,然后点击命令灯光模式图标。在“选项”选项卡下,点击“设置命令颜色”。命令列表将出现在左侧。选择你想要的颜色。
23条评论
i bought this key board less then a year so 6 months or slightly more and the U key and now the I key are not holding color they are turning puke green when they suppose to be blue.
jay biggumz - 回复 分享
that is the blue part of the rgb led being dead, red and green will still work but anything with blue is a no show.
Josh Smyth - 回复 分享
The app won’t work, it’s not loading, so I don’t have colour or light on my keyboard.
Lan Hamilton - 回复 分享
I can’t help but notice the macro keys have stopped working in Revit 2020 by Autodesk. It works on previous version which helps speed up the model and design production process. The lights also do not switch to the new profile like in the previous versions of Revit as well. This leads me to believe that Logitech may have changed the way the keyboard input works for the software because it works with the previous versions. I doubt Autodesk has changed the software to cause this issue or it would have appeared earlier. For many people developing the 3-D, VR and AR environments for the games people play, movies people watch and the buildings/homes people have built can you please look into this for the affected professionals like myself? Thank you.
Cadwerks.Studios - 回复 分享
I didn’t like G Hub when it first came out and I like it even less now. My keyboard will not light up and the keys that I had bound are no longer bound. This is a total mess
Debra Boinay - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 86
总计 44,922
