跳转到主内容
学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
耳机从设备中脱落
设备移动导致耳机脱落。
耳机腔内有异物
清洁/擦拭耳机与设备内部磁铁之间的表面。
磁铁损坏
如果耳机仍无法固定到位,可能需要更换设备内部的磁铁。
设备无法正常工作
线缆磨损或破损导致设备无法正常工作。
连接线断裂
剥去线缆外层的绝缘材料,并使用接线技术将断裂的线缆重新连接。
设备无法充电
设备充电两小时或更久后,电池指示灯仍为紫色或红色。
"如果无法充电,请更换充电器或电源线的电源来源。"
充电器损坏
检查充电器是否有明显的损坏迹象,例如烧焦或线缆磨损。
充电口故障
如果充电器看起来工作正常,请使用大头针或小型螺丝刀找到充电口内部的引脚。如果引脚弯曲,请尝试将其拨回正常状态。
Andrew Oglesby
于03/31/15注册
267 声望
撰写一个指南
团队
UMass Dartmouth, Team 2-2, Shastany Spring 2015 UMass Dartmouth, Team 2-2, Shastany Spring 2015 的会员
UMASSD-SHASTANY-S15S2G2
3 名成员
创作了12篇指南
54条评论
my headset keep saying vibrate off
Garrett Stewart - 回复 分享
You can't splice enameled wire.
Dirk Mittler - 回复 分享
The stock ear-pieces have thinly-braided, enameled leads, given color at one end of a single wire to denoted (+). I don't know whether that polarity-color-label extends into the covered length, that might be frayed. But if it does, then your greatest challenge might be, in de-insulating that kind of wire. Its insulation consists of a thin but tough, transparent coating. I found in my youth, that the easiest way to do that, was actually to hold a cigarette-lighter-flame to it for a few seconds. After that, you might be able to "splice" it, if you apply very good dexterity.
My HBS-750 is not connecting with Bluetooth or sometimes disconnecting after being connected. At the same time it started altering its voice. When the device say "Power On.... Trying to connect" it has now started to say it in a very high pitch or a very low pitch. When it says that in an abnormal pitch it will not connect via Bluetooth.
Doug Barrineau - 回复 分享
Headset was working great until a phone call. It is charged and connected but will not play
jodyk - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 44
总计 63,335
