跳转到主内容
学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
设备无法开机
电源开关损坏
电源开关可能已损坏,可能需要 更换。
电源线磨损
电源线可能已损坏,需要 更换。
机器漏汽或漏水
滤网篮漏水
试着找出泄漏的位置。如果蒸汽/水是从机器头和滤网篮之间漏出的,则可能需要更换密封垫(此处将链接指南)。
机器顶部漏水
如果蒸汽从机器顶部漏出,可能需要进一步拧紧盖子或更换密封垫。
蒸汽附件无法工作
附件堵塞
附件可能已堵塞,需要拆卸并清理或 更换。
水量不足
可能没有足够的水来产生蒸汽。请确保使用了足够的水。
加热器损坏
机器的加热元件可能已损坏,导致你无法制作咖啡或产生蒸汽。你可能需要 更换 水泵。
不出咖啡
咖啡粉压得太紧
如果咖啡粉在滤网篮中压得太紧,即使在压力下水也无法渗透。请将咖啡粉弄松。
锅炉内无水
锅炉内可能没有水。打开蒸汽阀门泄压,并检查锅炉内是否有水。
机器堵塞
机器可能被碎屑或矿物质沉积物堵塞。请清洁机器(此处将链接指南)。
制作的咖啡量不足
水量不足
在制作过程中,水会因冷凝和蒸发而流失。请添加一些额外的水。
正在漏水
机器可能正在漏水或漏汽。请关闭机器电源以检查密封垫(此处将链接指南)。
Paul Gilles
于10/12/14注册
14 声望
创作了0篇指南
团队
Cal Poly, Team 6-25, Maness Fall 2014 Cal Poly, Team 6-25, Maness Fall 2014 的会员
CPSU-MANESS-F14S6G25
4 名成员
创作了84篇指南
25条评论
Turned it in but won't work water in it put it sounds like the pump is not working any advise.
David Mills - 回复 分享
The issue doesn’t seem to be that the coffee is packed too tightly and no water/coffee is coming out, but that way too much watered down coffee/water comes out…nearly all at once. Am I not using a fine enough grind of coffee?
John Bethany - 回复 分享
The issue isn’t that the coffee is packed too tightly and no water can get through, but that too much water/coffee comes through almost instantly, so that the result is very weak coffee. Am I using too coarse of a grind of coffee?
the machine should have water to make steam but the water from the group head was dripping and the steam cannot steam
eduardo santos - 回复 分享
Please update your instructions to include under NOT ENOUGH COFFEE IS BEING MADE the following:
After replacing the gasket, if there is still a problem, you will likely need to keep the old grounds in the attachment that holds grounds and run vinegar through the system. Just as if you are going to make coffee, run a carafe of distilled vinegar through — this removes mineral buildup.
I have used this machine for decades and routine maintenance means running vinegar through it once every two or three years.
Anyway — love your project and love this espresso maker! Keep up the great work!
Chris Riseley - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 79
总计 26,644
