学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
绿色指示灯不亮
放大器通电后,绿色指示灯不亮。
电压故障
使用万用表检查电源端子,确保读数在 +12 伏到 +16 伏之间。确保连接已接地;如果指示灯仍然不亮,请参阅指示灯更换指南。
绿色指示灯亮,但无电源输出
绿色指示灯亮起,但放大器无法工作。
连接问题
检查所有连接,然后将设备连接到正常的扬声器,看看是否能正常工作。将其插入可靠的电源。将万用表设置为测量“交流”电压,检查输送给放大器的 RCA 线缆是否有信号。
播放大声音乐时红色指示灯闪烁?
播放大声音乐时,红色指示灯断断续续地闪烁。
电源不足
检查红灯是否亮起。如果亮起,说明电源不足。检查车辆充电系统中的所有连接。确保电池和交流发电机已充满电。
红色指示灯亮,但无音频输出?
红色指示灯亮起,但没有音频输出。
放大器过热
如果放大器温度过高,热保护功能将会启动。使用万用表测试扬声器端子的阻抗是否正常。确保放大器具有良好的通风散热条件。
电源输入问题
如果放大器仅在车辆行驶时关闭,说明电压保护电路已启动。如果供给放大器的电压不在 10–16 伏的工作范围内,请检查车辆的充电和电气系统。如果放大器只能在低音量下播放,说明短路保护功能已启动。检查扬声器线缆的所有部件,确保它们在车外没有被拉扯或磨损。
无输出或输出音量低?
扬声器没有声音或声音很小。
连接问题
确保平衡调节设置均匀,并确保连接线没有磨损或损坏。
交流发电机噪音——随发动机转速变化的啸叫声?
转速升高时,交流发电机随发动机发出啸叫声。
连接问题
确保连接线没有破裂或损坏,并确保它们处于正确的位置。同时,请确保增益设置处于合适的水平。
33条评论
What about a fast-flashing green light with no output?
Chris Skalski - 回复 分享
Did u ever find anything out mines doing the same
Justin madden - 回复 分享
My 300.1 works during cold weather, and is screwed into the back of the back seat in the trunk…..it only works now with the seath folded down. WORST BUY Installed it. I tried a new exact same amp and it just got hot with a red light. Arrrgghhhh i NEEEEEDSSS MY BASS!!
My PWR is sending voltage to my RMT. So my remote turn on lead has 12v coming from the amp which powers on anything it touches, even when the key is not in the ignition. Is there a way to fix this? Or how can I make the amp turn on only when I turn the radio on, without using a killswitch.
alex25ab - 回复 分享
Power should be to 12+ only, REM should be connected to a12v switched power separately. Aftermarket head units should have a Blue or blue/white stripe, remote/power antenna wire. Factory Radios May have them but not likely. In the case of factory head unit radios, I go to the fuse panel and locate a fuse that only has power when key is in the on or run position and use a tapping fuse pigtail. If you have the main power wire connected to both 12+ and REM the amp is constantly powered ON.
Dave Newton - 回复 分享
