跳转到主内容
学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
蓝牙传感器信号弱
设备无法通过蓝牙连接其他设备,或无法进入蓝牙配对模式。
开启蓝牙配对
询问 Cortana:“Hey Cortana, pair Bluetooth”,或按住蓝牙配对按钮。进入配对模式时,顶部面板会亮起。进入配对模式后,在你想要连接的设备上开启蓝牙,并选择 Invoke 扬声器。
拔下电源并重新接通
拔下电源线,等待十秒后再重新接通。当 Invoke 重新启动后,尝试再次进入蓝牙配对模式。
Factory reset speaker
=== 恢复出厂设置 ==
警告!所有设置都将被抹除。
在 Invoke 扬声器背面的麦克风开/关按钮左侧,有一个针孔,即恢复出厂设置按钮。用一根小针插入孔中并施加少量压力按下此按钮。如果操作正确,顶部面板将显示一个白圈。
LED 灯光暗淡或无反应
LED 灯不亮,或者有时闪烁,且在设备开启时无法保持常亮。
拔下电源并重新接通
拔下电源线,等待十秒后再重新接通。当 Invoke 重新启动后,检查 LED 灯是否亮起。
恢复出厂设置
警告!!所有设置都将被抹除。
LED 灯损坏
如果按照上述故障排除步骤后,LED 问题依然存在,可能需要更换 LED。
前往 LED 更换指南
扬声器声音失真
扬声器发出刺耳或不清晰的声音。
拔下电源并重新接通
恢复出厂设置
警告!所有设置都将被抹除。
扬声器故障
如果扬声器持续无法正常发声,可能需要更换一个或所有扬声器。
前往扬声器更换指南
Invoke 无法通电
设备无法启动。
电源线故障
线缆不应有任何撕裂或扭结,连接端不应弯曲或破损。
充电口故障
尝试晃动充电口中的电源线。如果充电口看起来异常松动,则可能需要更换充电口。
前往充电口更换指南
AI 无响应
当说出语音激活指令“Hey Cortana”时,Cortana 没有反应。
确保麦克风已开启
如果麦克风被静音,顶部面板上会出现一个红圈。要开启麦克风,请按下麦克风开/关按钮。
确保 Cortana 已设置好
确保 Cortana 应用已在其他设备上下载,并与 Invoke 扬声器正确设置。
42条评论
My invoke becomes unresponsive after a few mins whenplaying music from a paired Bluetooth device... every time. I did the whole setup as well as factory reset it already and same issue. I only use the invoke as a paired Bluetooth speaker, so it doesn't serve it's purpose when it keeps disconnecting. Please help!
Peter Bootoor - 回复 分享
Same issue here. Feels like the speaker is warm (not hot) near the top. 10-20 min max of play, and it will freeze completely. The light will then go amber and the unit reboots after a while. Really enjoy the sound from this device when it works, so this is very disappointing.
Rich Lockheart - 回复 分享
I am haveing an issue that started yesterday I just moved it to a different location and ever since then the led light sensor has been spiraling around and won’t even let me set it up to an account and so far I have tried holding down the microphone button, unplugging it and plugging it in, hitting the factory reset button. Also I have tried to see if I could do it manually with a mini usb male to usb male port and I did find connection problems because my computer would keep on restarting the device manager when I tried to run it does anyone know how to fix this.
kalebscott7798 - 回复 分享
Any luck? I’m having the same exact issue. One White LED circling around the top display. Powers on but unresponsive to bluetooth, mic button or reset pinhole. I don’t want to throw this speaker away.
rcheing - 回复 分享
Same. Looks like it is dead….
Andrey Stepanoff - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 87
总计 36,456
